Results 1 to 13 of 13
Thread: VS s pac boot lip help!!
    Vs Berlina Series 2
    Jun 2010
    Default VS s pac boot lip help!!
    ok guys i bought a vs s pack boot lip on a boot... i wanna put just the lip onto my boot thats on my car now...
    how do i remove the boot lip from 1 and put it onto the other without damaging it??
    dont want to use the whole boot cause my boot is full of sound deadning material and dont wanna have the hassel of changing it all over!
    please help if you know!
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Never really look at one but I'd assume it's bolted on from inside the boot.
    Verynice's Avatar
    Verynice is offline Band
    VS Caprice 5L
    Aug 2008
    SA - The Backwards State
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    If its genuine there's 3 x 10mm nuts you need to remove from the inside of the boot lid. One is smack in the middle and the other two are approx 50mm in from the outside. There is often a rubber blanking grommet to cover them. To fit to your boot you're going to have to drill the same 3 corresponding holes to mount it. Use a little non-hardening sealant such as window sealant/butyl mastic etc around each thread to prevent leaks.
    Lets hope the boot lid its currently fitted to is not on with urethane as people often do or it could be 'fun' to remove.
    Z' Series HSV 297KW 6lt LS2 Conversion For Sale!
    PM Me For Details
    Vs Berlina Series 2
    Jun 2010
    ahhk thanks heaps guys help is much appreciated... will attempt this on the weekend see how it goes haha
    Vs Berlina Series 2
    Jun 2010
    ok i have un done the bolts and the lip will not come off... been told not 2 pull 2 hard cause they pretty fragile!... any1 got any clues how 2 separate the 2 and get the lip off ?? need help
    vs berlina
    Sep 2010
    south coast n.s.w
    yeah from what ive heard they are sometimes stuck down with a type of glue simular to what they use on trolly strips and badges ect, my guess would be try to find where the glue is sticking the lip down and get under it nice and easy with a razor, but apparntly the lips can snap easy so take it easy once the lip starts to peal off
    Aug 2008
    NSW South Coast
    Quote Originally Posted by cander24 View Post
    Bugger, so its as I suggested may be the case...
    As above, DO NOT flex it too much. They can distort and break easily. The vs lip is more fragile than the vr as they are made of a different material. Get yourself a selection of retractable blade thin knives and slowly work the blade in in a stroking motion to slowly cut through whatever its glued on with. My last one took about 2hrs to cut off as it had been fitted with a heap of urethane.
    Good luck.
    PM Me For Details
    Vs Berlina Series 2
    Jun 2010
    yea im gonna have 2 start cutting away at it... not good with things that require patience haha... my #### head mate grabbed a flat head and chipped a little bit of it off but its hardly noticable and hopefully once its painted it will be good... time 2 get cutting... thanks guys keep u posted
    vr acclaim
    Oct 2011
    geelong vic
    fine guitar string and slip under the lip and slide it from each end that might loosen it up
    Xw GT replica/Vr s ute/Ef
    Jul 2011
    NSW
    9 out of 10 #### up they use the hardest glue on them they bend and crack good luck cheers.
    Vr ss & vy v6 wagon
    Jan 2010
    Central Coast, NSW
    yep be very careful removing it, i snapped one into 4 pieces trying to get it off a boot lid at the wreckers ages ago.
    Brendo169's Avatar
    Brendo169 is offline HSV Porn
    VS Senator
    Aug 2009
    WA
    use some fishing line...thats how i got mine off...wasnt easy tho
  1. Replies: 31
    Last Post: 21-03-2011, 05:23 PM
  2. Boot release broken, How do I open the boot to fix it?
    By CraigAB in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-10-2010, 08:54 PM
  3. Replies: 1
    Last Post: 29-08-2010, 07:16 AM
  4. [VIC] Trading Vy Spac Boot for Vy Boot with no Spoiler
    By TrEnNaVY in forum Swap / Wanted to Buy / Trade
    Last Post: 15-05-2009, 04:30 PM
  5. [SA] May Trade: VR Boot with SS Spoiler, for stocko boot.
    By StockoVRWagz in forum Swap / Wanted to Buy / Trade
    Last Post: 04-04-2009, 04:07 PM
