Results 1 to 16 of 16
Thread: cleaning rockers
    elmaso's Avatar
    elmaso is offline PARTY AND BULLSHIT!
    VR Calais
    Jul 2010
    Default cleaning rockers
    g'day y'all, im just wondering what i would use to clean the rockers and rocker cover?
    clean them with degreaser or something?
    because mine look pretty bloody shocking lol
    anyhoo cheers.
    Wombles's Avatar
    Wombles is offline Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    Are you removing the rockers?
    Clean them with kero or degreaser and/or brake clean.
    http://forums.justcommodores.com.au/...e-acclaim.html
    My Commy
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.
    Discuss.
    VS V6 TwinTurbo/VT SS Manual
    Sep 2005
    elmaso's Avatar
    VR Calais
    Jul 2010
    yep, saw em and it doesn't look nice lol
    and also i cant get the drivers side rocker cover off, because of one bolt up the back, how would i get the bastard?
    and another quick question, the torque specs for the rockers are 37-44nm?
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    I was wondering whether to clean the rockers themselves or not when I had my rocker covers off... anyone notice any difference? or just a good idea if you have the time?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by elmaso View Post
    Gregorys says Rocker arm retaining bolts - first stage 11-19Nm - second stage plus 87deg to 93deg.
    Rocker covers are 7-11Nm.
    Cleaning the rockers will not really achieve much except they look cleaner although you really cannot see them! I'd be very careful to plug all the oil drain holes in the head before removing the rockers to stop the crap draining down to the sump - if gets in there it will block the oil pickup strainer real quick. Good Luck.
    '94 VR Exec
    Feb 2010
    Wagga Wagga, NSW
    I found throttle body and carby cleaner worked a treat. You can soak the rockers in it and use it with a paint brush and some rag for the covers. Why not paint the covers while they are off?
    And with the drivers side cover, you need to bend the top radiator hose right away, and undo the hose thingy that connects to the brake thingy, to use the technical terms lol. Then it should come out with a little persuasion.
    WTB: VR/VS S/SS Lower front bumper lip/spoiler
    elmaso's Avatar
    VR Calais
    Jul 2010
    so do i chuck some oil over the push rods, rockers and valve springs before they go back in?
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    +1 for throttle body cleaner, worked great getting the crap off the inside of my rocker covers
    VS Berlina/ KJ Verada
    Sep 2006
    The drivers side is a pain in the arse to remove but you shouldn't have to take anything else off or apart to do it.
    95 VS Berlina
    http://forums.justcommodores.com.au/...ml#post1891856
    I need some statesman/ calais woodgrain for drivers side panel!!
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    When you reassemble lube everything that moves with friction i.e. valve stem tips, rocker tips, push rod ball and pushrod seat in the rocker arm. Use a molybdenum (moly) grease.
    To be honest though if your rockers/inside rocker covers are this bad id be more worried about the cleanliness in the rest of your motor. Sound like a pretty poor service history interval sorry.
    Z' Series HSV 297KW 6lt LS2 Conversion For Sale!
    PM Me For Details
    elmaso's Avatar
    VR Calais
    Jul 2010
    Aug 2008
    NSW South Coast
    Well its certainly not going to hurt, but if the rest of the motor is the same its not going to help a great deal. Also factor in that the stock rocker mounting bolts are a torque to yield, and theoretically are a single use.
    Should also add to my list above that after cleaning the rocker arms with any solvent degreaser etc that this will also flush out the oil in the rocker needle bearings. Make sure you try to pump plenty of oil back into the rollers before refitting.
    PM Me For Details
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
  15. #15
    Drawnnite's Avatar
    Drawnnite is offline Obviously Unsensible
    2000 Vs Ute
    Sep 2010
    could always go to the wreckers (pickapart for example)
    buy a set of rocker covers. take your time etc cleaning them/painting them
    put them on car.
    use old rockers for something like a into a set of pots for small plants like herbs for your old lady.
    cheap present, which could be a bit of fun aswell
    how about we make the pedals out of sticky rubber and the shoes with steel spikes. at least my shins would like that
    Quote Originally Posted by Jonesy484 View Post
    yeah i wondered the same thing when i was 4 when i grabbed the chrome exhaust of my dads rx7
    Quote Originally Posted by DM 55 WA View Post
    did you think it was a milo tin?
  16. #16
    vr
    Jul 2011
    adelaide
    sorry didnt read the thread
  1. Cleaning the IAC
    By joshy123 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-02-2012, 06:45 PM
  2. [VIC] Wtb or swap: 1.7 roller rockers for my 1.8 roller rockers for ls1
    By grantlyy in forum Swap / Wanted to Buy / Trade
    Last Post: 20-07-2011, 04:07 PM
  3. CAM and Rockers or just High Rockers?
    By vtv6 in forum V6 Development And Modification
    Last Post: 05-06-2011, 06:32 PM
  4. car cleaning help
    By guys-vr in forum Car Care Products
    Last Post: 15-11-2010, 07:42 PM
  5. cleaning the cas
    By dylan720 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-05-2010, 12:29 AM
