Page 1 of 2 12 LastLast
Results 1 to 25 of 31
Thread: remove firewall and hearter/aircon box??
    VP executive BT1
    Oct 2011
    newman, western australia
    Default remove firewall and hearter/aircon box??
    so i picked up a vr stato a couple days ago cheap as chips and i wanna put the dash in my vp, ive seen a few other blokes vn/vp with a vr/vs dash in them. absolutely love the look of it so i decided to have a go at it. whats the eastiest way to remove the fire wall and all the heater components??
    any help is muchly appreciated
    cheers justin
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    If you are going to install the dash anyway then I don't think there would be any need to remove the firewall. To get at the heater components you remove the entire dash.
    MY RIDE
    VP executive BT1
    Oct 2011
    i want to do a full conversion so everything works how it should, and that requires firewall from what i've read to be removed and put into vp. So everything lines up and goes back in how it should
    VP executive BT1
    Oct 2011
    vz wagon
    Aug 2006
    Wild west of Melb
    VP executive BT1
    Oct 2011
    alrighty cheers, would it be easier to rip the engine out to remove heater box then firewall you think?
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    Quote Originally Posted by Clutchy View Post
    Its glued in so maybe a heat gun.
    More like welded in?
    VS Berlina
    Mar 2011
    Woodford QLD
    I wondered about that when I saw it lol.. the firewall as far as I know is the bloody great piece of steel that separates the engine bay from the cabin.
    Are you sure its the firewall you want to remove? Never changed dashes over but removing a firewall is removing one of the major structural parts of the car isnt it?
    I had to laugh when I saw the heat gun and glue statement.. a firewall that comes out when it gets hot...
    EDIT: thinking on it, I guess there could be differences in the shape of the firewall that make it necessary to change that too. If this were the case, it would be a MAJOR job.
    You would need to cut the entire firewall out and weld in the replacement. The firewall is a part of the structural rigidity of the car, I would imagine the car would need to be on a jig to keep its shape whilst the transplant was done.
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    Quote Originally Posted by DAKSTER View Post
    I had to laugh when you laughed, while they won't easily come out with heat they are in fact glued in.
    VS Berlina
    Mar 2011
    Woodford QLD
    VP executive BT1
    Oct 2011
    should i just hack at t5he glue with a stanley knife or something similar? or get some acetone to try and eat away at? any suggestions? also thinking of welding it back in as i have a MIG welder sittin in the shed, also engine out or leave it in?
    VS UTE, HT MONARO REBUILD
    Dec 2010
    if you weld it in you could have a problem with warping and shrinking that would result in a distorted firewall. it could be done without warping it but it would be time consuming best to jig it up if your gonna weld it in.
    VP executive BT1
    Oct 2011
    Quote Originally Posted by Shooter 88 View Post
    prob best not to weld back in then, any clue what the glue is called and where i can get it from?
  15. #15
    BuckeTs's Avatar
    BuckeTs is offline Filthy Beast
    vs wagon
    Oct 2011
    Quote Originally Posted by wamboin23 View Post
    firewall is glued in. this is why commodores don't handle.
    Riiiiiiiiiiight. :/
    When in doubt, use FORCE
  16. #16
    woteva's Avatar
    woteva is offline NEED 4 SPEED
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    Quote Originally Posted by VP-EXCHASER View Post
    Try Repco, Super Cheap Auto, Bursons etc..
    http://woteva.tk/
    If it ain't broke... I can break it for you
  17. #17
    VS S Pack
    Sep 2009
    I think they used SIKAFLEX can get it from Bunnings but it is damned expensive, try someone that builds buses as they use it for gluing the panels onto buses
  18. #18
    VP executive BT1
    Oct 2011
  19. #19
    vz wagon
    Aug 2006
    Wild west of Melb
  20. #20
    vz wagon
    Aug 2006
    Wild west of Melb
    I know what a firewall is yes maybe i should of added a bit more to my first comment like using the heat gun wile cutting the glue might help but ya get that and I knew they were glued in as i have seen cars with them removed as they replace them with flat sheet metal in some speedway cars.
  21. #21
    VZ
    Oct 2010
    From experience that structural adhesive is very hard to work with. I tried to remove the firewall to make it easier to cut out a floor pan and failed. In the end it was easier leave the firewall in and use the plasma cutter
    Glenn
  22. #22
    VP executive BT1
    Oct 2011
  23. #23
    VZ
    Oct 2010
    holy shit!! planning on putting it back in at all?
    No. The VZ was a statutory right off and it is a donor for an EH ute that I am building. I kept the floor pan because I will need a biger tunnel for the VZ gearbox and a handbrake mount and seat mounts... bugger it all, I might even put the whole thing in the EH.
    Sorry to highjack the thread.
    Glenn
  24. #24
    VS GTS & VT XU6
    May 2011
    dude as many have said there glued and yes to get your vr stuff to fit 100% you will have to get the vr fire wall in there you will need to weld in supports so the body doesnt twist granted they dont do much been only glued they still play a major roll id ring holden to see if they sell the glue or talk to a body shop if you seach around i cant remember the site but there was a guy that had a supercharged and turboed VP or VN that did this mod and he had a heap of pics and it would make life alot easier havingthe engine and box out it would also reduce the chance of body twisting while doing it other than that good luck and have fun maybe best give a wrecker $50 to pull one out of there VN/VP's to practice
  25. #25
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    The glue we use at work is called "Carbond" http://www.holdfast.co.nz/pages/prod...t=7&psid=20054 - We have used this stuff for panelling the sides of busses, even stretch-forming and gluing entire rooves down.
    That being said, All the coachbuilders at work are certified in structural adhesive bonding, they know how to properly clean and prepare surfaces, they know how much panel overlap is required and they know how to properly apply the adhesive to get good coverage.
    What you are suggesting is a f**kn major job - Personally I wouldt bother with it if all you will be gaining is climate controll.
    A far better option, as I see it, is just cutting the relevant bits out of the VR firewall and stitching them into your vp firewall, even this is a big job and best left to a panelbeater.
    Why dont you just get the VR roadworthy and ditch the VP?
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    You All ARE Wrong About A Commodore Being A 4 Stroke Engine... Or Any Car For A Matter Of Fact...
    A V6 CAN'T Run On ONLY 1 Cylinder... IT'S A 24 STROKE ENGINE... 4 CYCLES Per Cylinder... "Basically Three V-Twins Together
  1. How do i remove door aircon vents
    By damoscommodore in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-08-2011, 11:44 PM
  2. AirCon - Keep or Remove?
    By Morton in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-03-2008, 10:39 PM
  3. Best way to remove heater hoses at firewall
    By commodore2004 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-08-2006, 05:42 PM
  4. Gently remove leaf cover from the firewall?
    By ProggerPete in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-02-2006, 09:42 AM
  5. Replies: 3
    Last Post: 28-11-2005, 11:23 PM
