Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By woteva
Thread: O2 Sensor - Taken Apart
    VS Acclaim S2
    Sep 2011
    Default O2 Sensor - Taken Apart
    I replace both my O2 Sensors.. I then proceeded to take one of them apart. It has the four wires, with the heater element. If you need a good 12v heating element, it can be taken out and re-used. The normal problem with these is the soot that accumulates and then hardens on the Zirconsensor.
    You can see the flakes lying beside it.
    Rds,
    Simmi
    woteva's Avatar
    woteva is offline NEED 4 SPEED
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    There was a $1 coin in there as well ??
    http://woteva.tk/
    If it ain't broke... I can break it for you
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Good Pic - always wondered what they had inside. Welcome to the forum Simmi.
  1. TPS Sensor Stuck TPS Sensor Low Voltage Indicator
    By tomjones1986 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-08-2011, 06:25 PM
  2. Where is the water temp sensor located on 98 vt ???? (not coolant temp sensor)
    By 13thomo13 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-05-2011, 10:19 AM
  3. HSV R8 front left wheel speed sensor - replace just sensor? or need to the whole hub?
    By hsvmaster in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-02-2011, 09:05 AM
  4. VH heat sensor and petrol sensor!
    By budgieVH in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-05-2009, 10:58 PM
  5. VN S1 Coolant sensor - Will a V8 sensor fit/work in a V6?
    By mulligan-can in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-05-2007, 09:08 AM
