Results 1 to 13 of 13
Thread: Shakes & loss of power
    96 Calais VS
    Oct 2011
    Tuncurry
    Default Shakes & loss of power
    I just purchased a VS Calais which lightly shakes on idle & really shakes when accelerating and has a loss of power. It's no better or worse the warmer it gets. The previous owner thought the bottom end bearing was gone but there's no knock. I just checked all the vacuum pipes, lines, air filter, tranny fluid, engine oil, radiator water, f/pump fuse & reset the ecu but nothing's changed. Any ideas? The airbag light stays on if that makes any difference to the problem.
    VY Series 2 Ute
    Oct 2011
    Newcastle
    VS Equipe
    Jan 2011
    Adelaide, SA
    Quote Originally Posted by VYSSII View Post
    Maybe the fuel filter?
    I had that issue at one point and was a blocked fuel filter.
    Have you checked the coil packs and leads, could be a very small missfire happening there
    96' VS Equipe (Current Project/Weekender) (CLICK HERE)
    Resident VR/VS Addict
    96 Calais VS
    Oct 2011
    Tuncurry
    Fuel filter never entered my mind lol Pretty stupid thing to forget considering the guy lived on a dirt road. The previous owner said he changed the plugs & leads hoping that would solve it, but didn't check the coil packs. OK, I'll start with the fuel filter & see how that goes.
    VS Equipe
    Jan 2011
    Adelaide, SA
    Quote Originally Posted by soleit View Post
    Well the fuel filter is completely sealed so dirt roads won't do anything.
    Its more, if he was living in the country running 91 from little independent servos he probably got a couple of bad batches of fuel at one point and the filter got loads of crap through it. (thats what happened to me, and why I never use liberty servo's anymore, was during ACA's blitz on the servos watering down fuel etc.....I got watered down 91 from a rusty fuel tank with rust flakes so big it clogged my fuel filter)
    96 Calais VS
    Oct 2011
    Tuncurry
    Changed fuel filter, no difference. So going to duck it up to servo, fill the tank up with 98 & run some injector cleaner through it and see what that does
    96 Calais VS
    Oct 2011
    Tuncurry
    Done & no change. Besides forking out the money for coil packs, any other thoughts?
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    How about the DFI and CAS?
    If your injectors are clogged with crap, injector cleaner will not fix that. I had to replace the filters in my injecotrs to sort out the miss I had (One was clogged badly), but new injectors would be a better option.
    VS Berlina/ KJ Verada
    Sep 2006
    Maybe you shouldn't have bought it knowing it had a problem? IMO just sell it and get a better one before you fork out heaps chasing an unknown problem...
    95 VS Berlina
    http://forums.justcommodores.com.au/...ml#post1891856
    I need some statesman/ calais woodgrain for drivers side panel!!
    nemesis_adrasteia's Avatar
    nemesis_adrasteia is offline better to reign in hell
    VR accliam, TF gemini, TC gemini, 79 isuzu ute
    Feb 2009
    longford, victoria
    sounds like coils to me.
    in stead of throwing money at it buying random parts hoping it will solve the problem, get a professional to diagnose the problem and go from there.
    "The mind is its own place, and in itself, can make a Heaven of Hell, a Hell of Heaven."
    apparently wasting my time with 97 cubic inches
    milk doesnt come in 1.6 litres
    my geminis
    James39's Avatar
    Jul 2009
    Newcastle NSW
    Quote Originally Posted by nemesis_adrasteia View Post
    When my VS had a miss and lack of power it turned out to be my injectors been clogged with crap, I changed the fuel filter and replaced the filter basket in the injectors and it solved my problem, I still need new injectors though.
    In saying this, bad injectors would give the same symptom like it was a bad coil.
    At the time I wish I checked the injectors before wasting money on another DFI and Coils
    96 Calais VS
    Oct 2011
    Tuncurry
    I am, problem is, my mechanic's away on holidays until Saturday and I don't trust any other around here. So kind of hoping to do minor things to see if it fixes it otherwise he can do the big stuff.
    96 Calais VS
    Oct 2011
    Tuncurry
    The DFI. That's it lol
  1. loss of power
    By rum runner in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-04-2011, 12:44 AM
  2. Vs no power and car shakes help plz
    By adstheman1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-04-2010, 04:48 PM
  3. power loss through lpg
    By vkhawkey in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-10-2006, 05:42 PM
  4. what causes power loss
    By HDT_aero in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-09-2005, 10:20 PM
  5. Power Loss
    By TheLucksta in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-03-2004, 09:11 PM
