Results 1 to 3 of 3
Thread: VS instrument cluster
    VS Acclaim 95
    Feb 2010
    Default VS instrument cluster
    Driving home this morning and the speedo has stopped working, it sits on 0 unless I go over a bump then just bounces all over the place. Everything else on the cluster (petrol, temp etc) works fine. Has the cluster died or a loose wire? Just want to make sure before replacing it.. Thanks!
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Check in the "how-to" section as there is something in there about broken printed circuit boards causing problems like yours.
    vr acclaim
    Oct 2011
    geelong vic
    try the transducer in the box first
  1. Will VE SS instrument cluster fit my VE SV6?
    By whatodo in forum VE Holden Commodore (2006 - ?)
    Last Post: 30-08-2011, 09:59 AM
  2. Installing A Vr Instrument Cluster Into A Level 1 Cluster Vn Exec
    By badly_drawn_boy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-07-2011, 02:41 PM
  3. VX Instrument Cluster Help...
    By Mr_Upgrader in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-05-2011, 07:03 PM
  4. instrument cluster
    By vy low in forum VY Holden Commodore (2002 - 2004)
    Last Post: 15-01-2007, 03:21 AM
  5. instrument cluster - help!
    By georgeonboost in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-12-2006, 10:01 PM
