Results 1 to 5 of 5
Thread: Info/advice/help vr conversions
    vt/
    Aug 2010
    qld
    Default Info/advice/help vr conversions
    Hi again i have been doing some reading on vr engine swaps as my 4runner has a vr motor with a original toyota manual box, The page i found was this one
    Conversions - V6
    This is a paragraph from it "If you are going to buy an engine only (as in a manual 4WD application), VN and VP engine packages are very simply, and can be used in automatic and manual situations without any major issues. If you are going to buy a VR V6 or later, it will need to have a manual ECM and engine harness. If you don't, you WILL have problems. VR's were the first to use an electronic transmission, as stated above, so the engine harness also includes a transmission harness. If this harness and PCM is used but not connected to a transmission, the PCM will think there is something severely wrong with the trans (because it isn't there), and a multitude of Malfunction codes will be set. When a code is set an ECM/PCM, the ECM/PCM will revert to "limp home mode", meaning that only basic programmed functions will be used, until the codes are repaired/removed."
    Now after reading that i know my 4runner uses a auto ecu (bffK) and motor from a vr, yet my original 4 runner 5 speed remains? so does this mean my ecu will have constant errors and will be in limp home mode? i have had the car for 3 years and theres been no real issues relating to the motor or performance i am just curious as i have started to enjoy working on the car.
    Im also planning on getting a memcal with no security no vats and was wondering if this may present new issues?
    VS Executive V8 S speed
    Dec 2009
    Balclutha NZ
    I'm running a VN 5L & 5 speedin a VS with VR auto computer and VR BCM. The check engine light is always on, but doesnt go into limp mode, it runs sweet as ever.
    vt/
    Aug 2010
    qld
    Quote Originally Posted by mrv8 View Post
    True, well like i said my car has always ran fine. i just read that write up and wondered how my car is functioning at all without the electronic data from the auto,
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    My understanding of LHM when the transmission fails is that the ECU will run the trans only in LHM....so engine parameters are not affected.
    I know that if the camshaft position sensor signal is missing, the ECU will use default values and same for oxygen sensors, but neither of these will cause the car to go into LHM.
    So I'd reckon it has no effect on engine performance.
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    I would guess your memcal has already been edited
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    You All ARE Wrong About A Commodore Being A 4 Stroke Engine... Or Any Car For A Matter Of Fact...
    A V6 CAN'T Run On ONLY 1 Cylinder... IT'S A 24 STROKE ENGINE... 4 CYCLES Per Cylinder... "Basically Three V-Twins Together
LinkBacks (?)
  1. VE SS Console, Stereo and AirCon not working ?? Advice or Info
    By Happydaze in forum VE Holden Commodore (2006 - ?)
    Last Post: 07-04-2011, 06:03 PM
  2. Getting mixed info, need advice on a respray(s)
    By RK5TAR in forum Spray Painting and Panel Beating
    Last Post: 05-09-2010, 09:23 PM
  3. Excellent Info on REbuild for L36 or L67 Great info...
    By vxcalais_01 in forum V6 Development And Modification
    Last Post: 22-05-2010, 12:26 PM
  4. LS Conversions
    By seannatt in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 12-11-2008, 06:28 PM
  5. Ecotech advice/info
    By Col74 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-05-2008, 06:41 PM
