Results 1 to 16 of 16
Thread: vr 5l bad on fuel, miss fire
    vt s pack manual
    May 2009
    gawler, adelaide
    Default vr 5l bad on fuel, miss fire
    hey guys, i bought this vr a little while ago, got it cheap. it had a bad miss fire when i got it, i got it checked out and the mechanic said it was dizzy cap, rotor, plugs and leads, i did this, it got better but never went away. i changed the map sensor last week, didnt do anything. ive also notice for a 5.0 its pretty pathetic in power. when its warm it gets alot worse, when i first start it up at work i put my foot down and it almost stalls. about a week after i got it, the fuel pump shat itself and thats been done since. i was thinking maybe o2 sensor? and it does around 300ks to a tank. wich isnt good because it takes me 3 tanks to see the week out.
    any idea's ?
    If you're not driving a manual, you are only steering, not driving
    VS Executive V8 S speed
    Dec 2009
    Balclutha NZ
    I would check the base timing, also injector service as well? I do heaps of K's in mine, and a tank is more than enough a week for me, I do like 600k a week, with fuel still left in the tank.
    VS Executive S2 V8
    Mar 2011
    Mildura, Vic
    Any error codes? Is your timing spot on? Have you done a compression test?
    holden commodore super 6
    Sep 2011
    delahey
    Get a mechanic to do a break down test or a leak test I think it's called
    vt s pack manual
    May 2009
    gawler, adelaide
    its been to the mechanics 3 times, no error codes. i havent done a compression test yet. not sure on the timing ? i got told it has a cam, but if it does theres something wrong it doesnt have enough power for a cammed 5.0
    dirt drifter's Avatar
    dirt drifter is offline white trash hillbillie
    VS 5L M5 VS 6L M6
    Apr 2009
    massive hole in the ground
    mine had a similar problem not long ago. missing real bad and chewing fuel but not lacking that much power, after replacing bloody everything it turned out to be a broken valvespring. if nothing else works maybe lift the rocker covers and check for a dud spring/ worn off cam lobe
    Quote Originally Posted by UFO View Post
    worked v8 + supercharger + dogbox = panty moistening equipment.
    4 banger turbos with bov's will just cry when they hear it, because they can never have it.
    Quote Originally Posted by GRPABT1 View Post
    Avoid cluey police
    vt s pack manual
    May 2009
    gawler, adelaide
    oh yay that sounds pretty fun, can this cause me to drop a valve ? because that killed a mates engine :/
    VS 5L M5 VS 6L M6
    Apr 2009
    yeah can do if the collets come out, if its ur problem to begin with that is. have u compression tested it yet?
    if u do lift the rocker covers to check that everything is ok under there i highly recommend getting some rubber gaskets, not the cheapo cork ones.. i got them first up and they blew out straight away!
    Avoid cluey police
    vt s pack manual
    May 2009
    gawler, adelaide
    nah i dont have a compression tester, ill ask the mechanics at work on monday, where should it be sitting around ?
    VS 5L M5 VS 6L M6
    Apr 2009
    as long as all cylinders are within 10% of each other they should be right. could be reading anywhere from 120-160 psi depending on how fresh the motor is
    Avoid cluey police
    vt s pack manual
    May 2009
    gawler, adelaide
    hey guys, a fella at work sugested to change my coolant temp sensor in the inlet manifold, a bit of dicking around and a can later, hey what do you know, no miss fire. buuuuuutt, for some reason in park/ N it sits at around 1500 rpm and in drive 1000, now the thing is this thing is suposed to have a cam in it, my theory is that because the sensor was stuffed it was'nt idle'ng right, i think that the old owner may have thought it was the tune and got the idle set higher, and now that the computer is getting the right reading the idle is now too high, does this sound right to you guys ? im going to phone a few places in the mornning and try get some one to have a look at my tune. doesnt help me not knowing the cam specs though. its not huge though.
    i did try to loosen the throttle cable and reset the computer but they didnt work, i thought it was worth a try though.
    VS Executive S2 V8
    Mar 2011
    Mildura, Vic
    Nothing will beat a custom tune specific for your cam.
    To adjust your idle, there is an adjustment screw for the throttle butterfly that sets how far your throttle is closing at idle. Try screwing it out maybe 2 turns to start with and see if it makes any difference to your idle. (Make sure there is enough slack in the throttle cable to allow it to close further.)
    It is also a possibility that your IAC (Idle Air Control) valve on the throttle is stuck open as well.
    vt s pack manual
    May 2009
    gawler, adelaide
    yeah i played around with that little screw and the throttle cable, it didnt make a diffrence. so my next thing is IAC, bursons are the only place that carry that kinda thing in stock, so getting one in the mornning hoping thats the problem.
    vt s pack manual
    May 2009
    gawler, adelaide
    ahhhhhhhhhhhhhhhhhhhhhhhhhh so i changed the IAC, the idle dropped and its miss firing again, #### this car lol.
  15. #15
    vt s pack manual
    May 2009
    gawler, adelaide
    anyone have any other ideas ? lol
  16. #16
    vt s pack manual
    May 2009
    gawler, adelaide
    i figured out, after i did everything, i put e10 in it, has anyone else had a problem with it ? ive spoken to a few people and they recon e10 is just crud and yeah...
  1. [NSW] VZ Intimitent Miss Fire
    By dogrusty in forum General
    Last Post: 31-12-2010, 10:32 PM
  2. vr v6 engine miss fire problem
    By lozz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-04-2010, 09:34 PM
  3. fuel spark but were is my fire
    By tailhappy vn in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-08-2009, 06:37 PM
  4. vh fire!
    By VH commodore in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-05-2008, 02:08 PM
  5. VT on Fire
    By nugatory in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-11-2007, 10:04 PM
