Hi guys, Im new here, I have the S-pac bodykit (skirts rather) on my car, but i am looking to replace it with either a senator GTS style bodykit, or a Clubsport bodykit, does anyone know / Have one they would like to trade or know where i might be able to find one ( In NSW prefereably ) ?
Are you looking for genuine or fibreglass? I have a genuine clubsport/senator front bar (which needs a little work before paint) and will also have a complete clubsport fibreglass kit for sale shortly.
PM me if you're interested.
Z' Series HSV 297KW 6lt LS2 Conversion For Sale!PM Me For Details
They aren't cheap or easy to find (not many seem to want the VR/VS ones anymore which means not many body shops make them anymore, everyone wants the VY/VZ style kits which look ridiculous on a VS which you will find for around $1500 from most custom body shops)
I spent ages looking for mine.
Paid $500 all up for a fibreglass replica kit (ended up costing more like $650 after paint/minor fibre glass stress repair)
A genuine one will probably cost you around $900-1200
just a heads up that some of the fibreglass replica kits are quite weak and dont fit without a little bit of tweaking
if i was you id be looking for something genuine as the plastic tends to flex and bend (where as the fibreglass just cracks)
My Senator 355 Stroker
http://forums.justcommodores.com.au/...5-stroker.html
Im fitting a fiberglass vr clubsport kit at the moment and its a fair bit of work. The rear and front bars are pretty hard to line up(alot of shaving and refitting) The side skirts and wing are pretty easy to fit. Just make sure you test fit before painting.
I was Lucky and got a Genuine Kit for $300, Everything lined up perfect apart from the Side skirts, seem a little short.
Took me ages to find a Genuine Kit.
I screwed the ends on the wheel arch and under the car then silflex on top to hold and seal the top
There is a screw hole at the back on the skirt itself and at the front and side of the section that sits under the guard, also under neath u can screw it 2 the body, for the Top they glue down with Sikaflex or Other Polyurethane based adhesive.
If it is a aftermarket copy it will just be a one piece Side-skirt that screws on front and back and glues down, not 2 pieces like the Genuine.
Thanks for the info... Looks like the one I have is an aftermarket copy.
