Results 1 to 10 of 10
Thread: Starter Motor Stuck
    VS Executive S2 V8
    Mar 2011
    Mildura, Vic
    Default Starter Motor Stuck
    I have a VS V8 Auto.
    New starter motor was put in about 5 months ago when the old one completely died and has been working fine until last weekend when it suddenly refused to turn over, and had to get towed home by the RACV.
    I have plenty of battery. The starter motor makes a clunk, being the solenoid activating when you try to start it, but then nothing. Gave the starter motor a bit of gentle nudge with a large heavy object, but still no go. Tried it with the car both in Park and Neutral.
    Got a replacement starter under warranty, installed it, and guess what - same thing - still no go.
    Bench tested old starter, works no problem. Tested starter wiring circuit, no problems.
    Got a socket onto the crankshaft/balancer bolt, manually turned over the engine a few times. Engine turned over normally.
    Tried the starter again, now it works no problems.
    I am happy that it is going, but won't be satisfied until I know why it happened in the first place.
    Any ideas from people with a similar experience? Stuffed ring gear maybe?
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Could be missing some teeth on the flywheel/flexplate. And when it stops in that area, there's nothing for the starter to turn. Hence your problem.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    VS Executive S2 V8
    Mar 2011
    Mildura, Vic
    Quote Originally Posted by Sabbath' View Post
    If that was the case, then when the starter motor hit that point I would expect the starter motor to spin freely. It doesn't, just totally refuses to turn at all.
    VY SS
    May 2011
    Auckland
    Can you try with the starter out but connected to the car turning it over? I'm thinking maybe there's an issue with the wiring and it can't supply enough current?
    Hangman's Avatar
    Hangman is online now Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    Can you turn the engine by hand?
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    Quote Originally Posted by Hangman View Post
    Yes, as he said.....
    Quote Originally Posted by Scrubmonk View Post
    Hangman's Avatar
    Jan 2010
    Yeah, missed that line. Obviously.
    VS Executive S2 V8
    Mar 2011
    Mildura, Vic
    Thanks everyone for their replies. I am convinced that it is something mechanical rather than electrical as the starter tested OK out of the engine. The new starter is working as it should, once I cranked the engine over by hand a few times.
    I starting to wonder if maybe something has come loose in the flew plate area, and is randomly jamming the starter? If I end up having to take the auto out, it will definitely be a manual box going back in.
    vr acclaim
    Oct 2011
    geelong vic
    checkthe wiring to the starter. it could even be a relay, it doesnt sound mechanical as the started tested off the car, it sounds like the solinoid is throwing out but there is no drive to the starter in the car???
    VS Executive S2 V8
    Mar 2011
    Mildura, Vic
    It did it again the other day. Turned the engine over by hand, still no go. Notice that the leads on the positive battery terminal were a bit loose. Tightened them up and away it went. My guess is that it was getting enough current to throw the solinoid, but not enough to turn the starter. I hope this is the problem, as it was an easy fix.
  1. Ignition stuck, starter keeps cranking, have to manually turm key back when starting
    By Krilnik in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-09-2010, 03:34 AM
  2. starter motor solinoid stuck
    By Lowwwerd vs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-06-2010, 01:34 PM
  3. VX Starter Motor
    By Maxseverity in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-11-2009, 08:15 AM
  4. [VIC] WTB Starter motor to suit VC Blue motor 202.
    By Drewie in forum Swap / Wanted to Buy / Trade
    Last Post: 11-05-2009, 01:09 PM
  5. will a manual box starter motor fit on a auto box motor?
    By lil_oneblue in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-09-2007, 05:17 PM
