Results 1 to 14 of 14
Thread: bleeding brakes on a car with abs
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    Default bleeding brakes on a car with abs
    Ive bled the brakes on heaps of cars, done the master cylinder upgrade on cars with conventional non abs brakes without incident but havent tried doing it to a abs car.
    Im thinking about doing a master vx upgrade on a vs with abs...any thing to be aware of when bleeding it?
    Is there any special tools needed?
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    holden commodore super 6
    Sep 2011
    delahey
    Not really just bleed longest point to shortest. Easy as crack the bleeder on longest and let drip for a bit then continue until u get to the shortest point
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    I cant say for sure mark, but i've done 2 vr ABS v8's(mine and a mates). I have had no issues with the ABS module, but i never let the resovoir run dry while bleeding the brakes (just as u usually do on any other car, the abs dosnt change the way you bleed the brakes), and also i make sure the lines are bent up as soon as they are removed so the fluid dosnt run out(not that much comes out anywayz, just a precaution to stop air locks)
    From what im aware if you get an air lock in the abs module, your kinda stuffed and have to get tech1/2 on it to pules the abs to get it out. I do remeber a thread on here where i read that someone had this issue and they just either, 1>pulled out a wheel sensor or 2>strapped a nut or somthing metal over the removed sensor, to trick the abs to thinking a wheel is locked and causes it to pulse. The car was on jack stands and put in drive for this, which sounds dodgy but could get you out of a jam.
    Now i dont know if you have to have pressure on the pedal, or lines cracked while the abs is pulsing, or maybe the pulsing just pushs back the air lock, or if this even works at all! But just passing on what i read It does sound feasible though.
    Reaper
    vs commodore
    Oct 2009
    Tamworth NSW
    If you bleed the brakes, and still find that they are a bit spongey, try locking up the brakes a few times on grass or gravel, which will activate the ABS modulator, letting any trapped air through, so it can be bled out, then rebleed them again. Dont let the master cylinder get below 3/4 from the full mark whilst doing the bleeding process, as it can easily suck in more air once the brake fluid gets a bit low.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    As long as you bench bleed the master cylinder before you instal it you should be right.
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    Ive bled many commo brake systems with ABS... VT setups on VS etc. I just do it as normal, never had any problems.
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    Quote Originally Posted by Brett_jjj View Post
    Locking the brakes won't be necessary, just an easy drive around the block - pumping the brake pedal - this will push the air thru the lines and then rebleed the system
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by Munz View Post
    If theres any air trapped in the ABS modulator, just driving the car around the block wont activate the ABS to let the trapped air out from behind the actuators in the ABS module. Most quality scantools have an ABS brake bleed option which activates the ABS, this is so any trapped air in the ABS modulator can be let through to the calipers where it can be bled out. I use a Tech 1 scantool for this. I guess most aftermarket scantools would also have the same brake bleed option available. Locking the brakes is just a "backyard mechanics" way of activating the ABS. Ive bled a lot of brakes with ABS, and I hardly ever have a problem with air trapped in brake systems. But on the odd occasion, Ive ran into problems where Ive needed to use the scantool to get the air out of the system, and get the brake pedal firm where its supposed to be.. You would be suprised how much air can end up trapped in the ABS modulator.
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    So where does the air go when you do this?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by RX25SE View Post
    It goes towards the caliper and then it returns from the caliper...unless the air is released from the system it will still be there.
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    Quote Originally Posted by hako View Post
    Haha...
    I've probably bled as many brakes as you Hako!
    I was more curious about the logic behind the comment.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Haha...
    The real problem with pumping the brakes whilst air is in the lines is that the brake fluid becomes aerated with millions of microscopic air bubbles getting trapped in the fluid - only real fix then is a complete flush - this is also a reason why you don't re-use the brake fluid pumped out when bleeding.
    Completely off topic, but I bought a '38 Chev Master back quite a few years...brakes were a bit spongy and pedal would not return so decided to bleed them and found the seller (dodgy car yard on Parramatta Rd) had used engine oil instead of brake fluid - apparently to swell the brake rubbers and stop leaks. There was no easy fix for that and it ended up at Sydney Showgrounds as a stock car where brakes were optional....it was a real shame to see all those solid 1930-40 Ford,Chevs and Chryslers etc being smashed to scrap every weekend at the stock car derbys....good fun but.
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    NOOOO.......
    I've seen dodgy stuff before, but never engine oil in place of brake fluid!
    Behaviour like that is what gives mechanics a bad name.
    1996 VS HSV Clubsport Manual, 1998 HSV Clubsport
    Oct 2011
    New Zealand
    Smile How I got mine to work
    I had exactly the same problem. Squishy Pedal all of a sudden. Got brakes bled, no different. Did calliper seals on all corners, same squishy pedal feeling. Next was master cylinder - you guessed it, same squishy pedal. Was at a loss as next up was the option of braided brake lines. No thanks as they are over $500 installed in New Zealand!!!!
    Looked at this thread Saturday lunchtime and saw what Brett_jjj had said in a reply: "If you bleed the brakes, and still find that they are a bit spongey, try locking up the brakes a few times on grass or gravel, which will activate the ABS modulator, letting any trapped air through, so it can be bled out"
    I did this on the road straight after I read it, slammed brakes on at about 50kph. Pedal straight down no ABS activation. Tried again ABS kicked straight in, but pedal felt better. Did it a 3rd time and hey presto!!! ABS on straight away and pedal is now ROCK SOLID!!!!
    Looks like is was inside the ABS module as you said. Been driving today and pedal is fantastic!!! No need to re-bleed the system.
    So thank you so much guys for all your input. I may have spent around $600 doing everything but you saved me another $500 so much appreciated.
    You guys ROCK!!!!
  1. Bleeding brakes
    By DANNY8 in forum General
    Last Post: 05-11-2009, 08:25 PM
  2. Bleeding ABS Brakes
    By thestig in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-01-2009, 10:01 PM
  3. Bleeding brakes
    By LightningVP in forum General
    Last Post: 14-10-2008, 11:42 PM
  4. bleeding brakes
    By tara1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-03-2007, 12:41 PM
  5. bleeding brakes
    By gammin in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 13-11-2005, 04:25 PM
