Results 1 to 5 of 5
Thread: need advice on vs statesman engine change.
    Vs Statesman
    Oct 2011
    Harden Nsw
    Default need advice on vs statesman engine change.
    hey all. i need some advice on an engine change i wanna do.
    i just got a vs statesman with a v6 with 358000ks... i want to change the motor for one with lower ks. but im wondering if a vt/vx ecotech would work in my car or would i be better of just getting a vs motor? i just thought that all ecotecs are the same.
    oh and mine is currently duel fuel.
    any advice would be good. thanks in advance..
    stuartl1989 is offline Its not your's
    96 VS
    Feb 2011
    Caboolture
    pretty sure all ecotecs are exactly the same until VY and thats just a plug or two for installation....
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    You need a few things from your VS motor. Like the inlet manifold and engine mounts and I think a pulley that is for your current air con...
    Vs Statesman
    Oct 2011
    Harden Nsw
    sweet as thanks guys. i wanna do it soon as the current engine has 358000ks..... if i was to use a vt/vx ecotec would i need to use the ecu or anything from the donor car?
    1996 VS BT1 SS 5ltr original
    Apr 2008
    Vx motor into a vs information of what i did
    this is all you need to know.
  1. gearbox change?? advice
    By stock_vl in forum VL Holden Commodore (1986 - 1988)
    Last Post: 16-01-2012, 01:31 AM
  2. Vz v6 LSD diff and ratio change advice please
    By ScufVZwags in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 30-07-2011, 11:13 AM
  3. oil change advice
    By carpetsnake in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-03-2008, 07:05 PM
  4. need to change gearbox need advice/tips
    By Gazza2005au in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-07-2006, 09:46 PM
  5. Urgent Advice - How to change a bumper!
    By GDSGFT in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-03-2006, 11:29 AM
