Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By hako
Thread: Transmission Problem :(
    VS Berlina Series II
    Apr 2011
    NSW
    Default Transmission Problem :(
    Hey guys
    I've got a problem with my car. (vs commodore)
    RE-EDITED
    gears are messed up
    park = park
    R = Drive ( i think its full range of gears)
    N = Drive ( i think its full range of gears)
    D = Drive ( i think its full range of gears)
    i'm too afraid to put my foot down or change into 3rd 2nd and 1st incase i do damage to it
    i'm abit worried cause i only got the car not long ago so any help with be greatly appreciated.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    It sounds like the selector arm is loose where it meets the transmission and slipping. I'd jack the car up safely with stands underneath, and then get under the transmission whilst having an assistant move the T bar.....you will see it move and hopefully figure out how to tighten it.
    Apr 2011
    NSW
    thanks hako i'll have a look today when it stops raining
    i honestly dont know how it happened. i was driving back from canberra goin thru the clive mountains. was dropping it back from D to 3rd to save my brakes. didnt even know i did damage to it until i got home and had to leave agian.
    i'm hoping its the selector arm.. fingers crossed.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    There are details in the Gregory manual on adjusting the linkage which I can copy for you if you discover it is the linkage.
    Apr 2011
    NSW
    heading over to a mates place tonight so i can use his ramps and stands ( alot safer i think )
    i checked the fluids and there is no burnt smell and its still red.
    i'll try and work on it tonight, that would be awesome if i could grab that off you plz
    Fingers crossed.
    and thanks once again for advice and helping out mate
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    PM me your email address and I'll scan the pages.
    Apr 2011
    NSW
    hey hako
    thanks for those images.they helped alot.
    doesnt appear to be the selector arm so my only guess is the solaniods.. or even something worse... oh well was worth a try i guess
    a mate has a box i could grab but its from a vx ute?
    so i'm wondering if it will fit. they all use the same 4L60e ??
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Have a look at the attached link - item number 8. - this is what happened to me about 7 years ago although I had reverse for about 10 metres....was driving up the range at Tambourine and trans made a 'click' and changed back to 3rd, stayed there but car seemed stiff - pulled up about 1km further and that was it. $2000 later I had a new trans.
    So I do hope this isn't the case with you. Good Luck.
    http://www.s10forum.com/forum/f13/4l...utions-297698/
    Apr 2011
    NSW
    rebulit required. i kinda hoped it wouldnt be the case but cant always have good luck
    so now i'm trying to work out if a vx gearbox will fit.
    hako your just aweseome, seriously thankyou very much for being so helpful
  1. VS V6 Transmission Problem
    By AzaIzDaMAn in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-05-2010, 01:39 AM
  2. VR Transmission Problem
    By CommodoreMan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-07-2009, 10:02 AM
  3. Transmission problem....i think...
    By Billo55 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-04-2007, 09:55 AM
  4. transmission problem with vn.help.
    By knighty in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-06-2005, 07:11 PM
  5. Problem with transmission :(
    By bad_boyz in forum VL Holden Commodore (1986 - 1988)
    Last Post: 12-09-2004, 04:18 PM
