Results 1 to 4 of 4
Thread: VR air con pressure switches.
    VS Executive V8 S speed
    Dec 2009
    Balclutha NZ
    Default VR air con pressure switches.
    Hi all, I'm installing air con into my VR, can anyone tell how many pressure sensors the A/C has and where they are located? I can only find wiring plug, yet the kit has 2 sensors. I have already installed climate, which is functional, so not sure if this makes any difference? Or would anyone have a clear wiring diagram they could share? All the ones I searched on here I couldn't read. Thanx in advance, Anthony.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The wiring diagram in Gregorys shows one A/C pressure switch (low I presume) and also a high temp cutout at the compressor - this makes sense as gas temp will be evident at the compressor and is directly related to gas pressure. PM me your email if you want a scan of the wiring diagram.
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    VR will be running a binary switch. this means it will be off below a certain pressure, then on within a range, then turn off above a certain pressure.
    So the one switch is both high and low pressure.
    Dec 2009
    Balclutha NZ
    AH Thanx guys, helps alot, Anthony
  1. VQ SII switches
    By GMBanisher in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-03-2009, 05:42 PM
  2. Switches Behind Power Window Switches
    By extremeaudiowa in forum VY Holden Commodore (2002 - 2004)
    Last Post: 11-05-2007, 10:38 AM
  3. switches
    By naf33n in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 19-10-2006, 05:39 PM
  4. oil pressure gauge, oil pressure
    By VN-88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-10-2005, 10:31 PM
