Results 1 to 6 of 6
Thread: Vs Battery Light
    Vs Commodore Executive
    Sep 2011
    Gold Coast
    Default Vs Battery Light
    When my car is started my battery light is on and sometimes flickers, is this a loose terminal, cause they are dead tight, do i need a better battery or is my altenator screwed?
    Thanks James
    VP calais
    Jun 2011
    sydney
    most likely its your alternator i had the same thing in my old car. you could clean your terminals properly and see if that stops it it could be just there really dirty
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    The brushes would be on their way out in the alternator. Should be able to replace the regulator and brushes for around $45 new.....
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Dud regulator (this contains the brushes)
    Also make sure the B+ terminal is tight and the cable running to it it not burnt at the end.
    You really should be 'dressing' (restoring the running surface) the slip rings (the contacts the brushes run on) when replacing the regulator/brushes.
    Sep 2011
    Gold Coast
    okay thanks very much
  1. Please Help..Battery warning light and ABS light
    By martyrfc in forum Electrical Wiring / Questions
    Last Post: 30-04-2011, 03:03 PM
  2. Replies: 3
    Last Post: 26-05-2010, 09:22 PM
  3. battery light with brand new battery
    By andyli in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-03-2010, 09:48 AM
  4. Engine stops, fuel light on, battery light on GOODBYE
    By scarletx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-06-2009, 03:43 PM
  5. Battery light & Check Engine light
    By Sledge in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2008, 06:30 PM
