Results 1 to 3 of 3
Thread: transmission???
    1993 Vr executive v6 3.8L
    Nov 2010
    Central Coast
    Default transmission???
    so my transmission is playing up and was wondering if anybody could help me or something
    my reverse is completely gone but all other gears are fine if anything there better then before
    sometimes it rolls when put in reverse like it works normally but when yu go to rev it, it just revs and doesnt move
    does anyone know whats wrong with it is time for a new one or can it be fixed somehow???
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Common failures on 4L60E, symptom < cause > any possible repair:
    1. Slow, slipping or no reverse: “lo-reverse” clutches are worn out, fluid leak in the reverse apply circuit, or broken sunshell. It is possible to remedy a fluid problem by removing the checkball from its cage in the case in the rear of the trans may help (must remove valve body), or adding a high-viscosity additive such as Lucas Transmission additive or other seal restorer product. May also have worn boost valve (can replace in the pan).
    VN S Pac, VR Berlina, VE 'V'
    Jul 2005
    i would say it well on the way out. they are renowned for dropping gears i lost 2nd in mine. clutches and bands let go especially if not serviced regularly. many people dont realise how regular oil and filter changes can help. mine died from the supercharger i strapped onto it!!
  1. radiator differences 2 transmission lines or 4 transmission lines...
    By Darkk_Calais in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-01-2010, 12:10 PM
  2. My VS Transmission - how bad is it?
    By rock in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-05-2009, 09:45 PM
  3. Transmission
    By Leebo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-03-2009, 04:53 PM
  4. Replies: 0
    Last Post: 17-11-2008, 01:51 PM
  5. Code 68 - Transmission Component Slipping - Auto Transmission Only
    By tysons_2001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2006, 05:14 PM
