Results 1 to 2 of 2
Thread: wierd problem.
    VS Acclaim 95
    Feb 2010
    Default wierd problem.
    Hi all,
    I have a 95 vs acclaim , I put in a new indicator stalk in the other day, then this is when my problem started.
    Went down the street did some shopping got back in my car went to start it, nothing happened the lights on the dash came on,
    but the car did not turn over. So i moved the gearstick from park to first and back a couple of times, tried again and still nothing.
    So i tried another three times just turning the key then the car started no probs.
    Went to go out a bit latter same problem starting it. Went out this morning same problem,
    Just tried it before had no problem started the car 15 times. Does any one have a idea what is going on
    , I really don't want to get stuck some where.
    VN S Pac, VR Berlina, VE 'V'
    Jul 2005
    check that the contact around the key hole and on the key are clean or that the ring is in correct position after removing column shroud!!
  1. wierd heating problem
    By razzar in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-08-2011, 04:37 PM
  2. Wierd electrical problem
    By Longman in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-11-2010, 07:51 PM
  3. wierd ve problem
    By programer in forum VE Holden Commodore (2006 - ?)
    Last Post: 21-04-2010, 06:59 PM
  4. Very wierd electrical problem
    By down_with_the_system in forum Electrical Wiring / Questions
    Last Post: 19-04-2006, 09:53 PM
  5. wierd problem
    By VRSS in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-04-2006, 03:05 PM
