Results 1 to 10 of 10
Like Tree2Likes
  • 2 Post By Andrew426
Thread: HELP shes dying
    vr commodore v6
    Dec 2009
    Question HELP shes dying
    hay guys , ill get right to the point my commodore vs s pack 95 , a few injectors had the ceramic plating around the tip ,broke off inside my head, i have never removed cylinder heads before, i need to no if the lifters come of in a rail system or individually are they hydrolic. i need the basic of removing an replacing safely , an can i turn engine by hand without taking off all the pullys an water pump an stuff or by tool, Or can i just take my plugs out an runs some fuel through where the injectors spray an hope it washes out ,also my manifold gasket split whilst in operation an when i pulled of my manifold a bunch of water slipped into the bay underneath not a major amount from what i could see then i relised it could of drained into lower block, but it was still all over my push rods ,i drainned oil an put new oil after spraying a shit load of water dispercant in there an drained again . now is there any spots it can sit around underneath where the manifold joins i noticed a small hole at each end of where manifold join an i shit myself plaese help guys i spewin all the help i can get only 3 weeks old my new baby is dying.
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    Bro... If your 3 week old baby is dying, this is not the place to be asking for help. Call an ambulance.
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    You All ARE Wrong About A Commodore Being A 4 Stroke Engine... Or Any Car For A Matter Of Fact...
    A V6 CAN'T Run On ONLY 1 Cylinder... IT'S A 24 STROKE ENGINE... 4 CYCLES Per Cylinder... "Basically Three V-Twins Together
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    I have lost the pintles off my injectors down the hole too, I did not worry about it and has no effect on the motor at all....
    vr commodore v6
    Dec 2009
    vr commodore v6
    Dec 2009
    mine isnt running the same man mine didnt even have a rattle now it wont even idle perfect
    vr commodore v6
    Dec 2009
    does ane one have the anwsers too the rest of my questions not just the one they want anwser, i am mechanically minded so some one with some experiance in wat im talking about would be nicethnks/.
    VS Executive S2 V8
    Mar 2011
    Mildura, Vic
    The ceramic coating your are talking about is called a Pintle Cap. Are you sure it is ceramic, or just brittle plastic? Mine were plastic (but this was also on a V8), lost part of one down the intake port. Must have just burnt up, as it made no difference. My understanding though is that you will need to replace the Pintle Cap as they have an effect on the spray pattern of the injector. Unfortunately I found that Bursons etc only sell them in bags of 50, so I had to find a willing mechanic to sell me a couple of spare ones.
    Removing your cylinder heads would be a last resort. See if you can blow it out with compressed air, or even suck it out with a vacum cleaner.
    Your manifold gasket needs replacing by the sounds of it. As for the water, drain the coolant before you do anything like taking off the manifold. Is there any coolant in your sump? Can you see any on your dip stick. I would be changing the oil and filter before going any further.
    vr commodore v6
    Dec 2009
    vr commodore v6
    Dec 2009
    vr commodore v6
    Dec 2009
    workin pretty well im just worried if there is any water deposits i didnt find will cause a problem in future
  1. Shes The Last Of The VLs
    By Troy92 in forum VL
    Last Post: 29-08-2009, 09:05 AM
  2. heater tap fixd, now shes OVERHEATING
    By PSYKO PHOENIX in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2008, 04:50 AM
  3. how much do ya think shes worth
    By fuzzy2308 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-11-2008, 09:16 PM
  4. shes a slippin!! (automatic transmission)
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-12-2006, 06:24 PM
  5. Shes REALLY worried about her kid
    By The1985divo in forum Jokes/Humour
    Last Post: 19-10-2004, 08:58 AM
Tags for this Thread
