Results 1 to 5 of 5
Thread: VS 5l manual ute misfiring if revved past 3500 rpm
    VS ute
    Jun 2009
    Default VS 5l manual ute misfiring if revved past 3500 rpm
    G'day ive got a vs 5l manual ute which revs out fine to 3500 rpm, but kinda dies off and starts misfiring/running rough for a fewseconds afterwoods, i did a fault code check and came up with
    Code 12 - System Pass (OK)
    Code 16 - ECT Sensor - Voltage Unstable - Auto Transmission Only
    any help would be much appreciated Braeden
    VS Senator
    Oct 2009
    Is it an auto model thats been converted to manual or is it a factory 5 speed ute
    VS ute
    Jun 2009
    original manual, left oxygen sensor wiring looks like its had a bit of heat, so i un plugged it and went for a drive and it still does it but when i rechecked the codes with it unplugged it still only came up with 12 and 16
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Sounds like the dizzy cap or the coil. Or it could be a dodgy lead or spark plug. Check them out.
    Reaper
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    DTC16 is NOT an auto only DTC, it applies to V8 manuals as well as autos. You need to check out the sensor wiring to make sure there are no shorts and/or replace the sensor (around $15 from Holden last time I bought one). However, I can't see that causing your misfiring problem. Agree with VrWagz1 on the leads (especially the coil lead), plugs, cap (and rotor). Leave coil to last as it's a bugger to replace - although if you are replacing the distributor cap you are half-way there.
  1. [SA] White vp commodore ute - v6 5 speed manual - $3500 adelaide
    By Skidney in forum Vehicles For Sale
    Last Post: 25-03-2010, 02:29 PM
  2. VN S1 Auto wont rev past 3500 in gear, 4500 in neutral
    By shmickmik in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-11-2008, 01:57 PM
  3. Cant rev past 3500
    By FullySik in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-10-2008, 07:22 AM
