My power windows in my VS are getting slower and slower, one has even stopped entirely. I know they would never be as fast as new car's windows, but it sounds as if they are seriously labouring on both the rise and the lower. I've also noticed a voltage drop while the window struggles. What is the likely cause of this? Motors, regulators, lubrication?
What should I start with?
put some dry lube on the weather seals and try it again, see if it speeds it up
I had a motor burn out, which had to be replaced. But before it did die it gradually struggled until it died. I use a silicon spray on the runners every week or two now and the windows don't struggle and run fine.
http://tinyurl.com/MetalisAwesome
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
Albert Einstein
+1 for silicon spray in the runners.
Im sure i read this on here once before. I think it said the issue is more the rubber runners once its inside the door and not so much in the window frame itself. But that could complete bs too. But yeah, the fluff coating will wear off the rubber over time and just cause a rubber to glass friction and yes you can burn a motor out. Id go more for the MrSheen option as it dosnt attract dirt and dust to the rubbers which in time will cause more friction. Anything wet like (eg. wd40, lube sprays, oils) will only clag up with time.
As above. The runners towards the front of the car on the front doors need to be aligned. Also is this when the car is running? If the car is switched off thats your prob there. As your electronics run better when the alt is going. You want to use some lithium based grease for your tracks and that, its a far better grease for this as i have found.
VR and VS error codes:
VS V8 DTC/Error codes comprehensive list.
VS V6 DTC/Error codes comprehensive list.
had a vs that would do that, normally after sitting for a month. have the battery condition checked.
silicon spray as others have said and upgrade your wiring bigger cable to the alternator and biger cable from neg. on battery to the engine and the body of the car i did this and notices a improved speed with my windows and louder stereo plus a few other things factory wiring and battery terminals leave alot to be desired up grade them and you will be glad u did
Well both my VS's displayed the same symtoms, then one day BANG!. i've figured out it wasn't the runners needing lube though it did help but not the origin of the problem. It was in fact the rivets holding the
regulator to the door frame (two of four had sheared and the other two were loose and on their way out) loosening over time and slightly misaligning the regulator in its mounting. The window starts to get
slower and slower due to there being unstable mounts then you either bend a regulator arm or you shear a few rivets or both. so from my experience pull your door skin off wind the window down half way,
then check for play in the rivets by just giving everything a wiggle and give the glass a good tug up and down and if there is play replace the rivets with good grade bolts (even if theres no play IMO its very
wise to replace them anyway) dont ever put the bloody rivets back in because the problem will repeat (i found out the expensive way OEM regulators are $200+ and non OEM are cheaper but shit and will break
again and put you back at square one) use Good grade bolts.
Stuntmanmike: At least he didn't advise for me to check the head light fluid and bring it in to tune the radio...
