Results 1 to 6 of 6
Thread: VS Level 3 cluster illumination
    writeoff's Avatar
    writeoff is offline 0 to 100... eventually
    VS Wagon
    Jul 2011
    Default VS Level 3 cluster illumination
    So I recently upgraded from a Level 2 cluster to Level 3. Yesterday, the backlight illumination just stopped working, the left one flickers occasionally but the other two don't even do that, nothing at all. I checked fuses and they are all fine. All other illumination works. FYI, I havent upgraded the loom yet, I am just checking if it is worth the upgrade but it worked fine for about a week. I did change the indicator globes to LEDs in the bottom strip the day before it happened although it worked 100% then till I started it the next day. Any suggestions?
    Be patient, I am inquisitive and I am learning.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    If the globes are not working after testing OK and fuse is OK - then the earth track or + track for the lights is damaged some place on the back of the cluster.
    Fit your L2 back in to see if it lights up OK.
    and 3 Dangerous non ABS VN's
    writeoff's Avatar
    VS Wagon
    Jul 2011
    Globes are fine, fuse looked fine but I swapped any way, all tracks appear in good nick. The old cluster illuminates with out a hitch.
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by writeoff View Post
    The level 2 and level 3 cluster gauge lights work off the same power feed. So the issue is with the contact of the globes.
    Try to close the tags a little bit - not to tight as it will melt the plastic over time. But it needs to be firm.
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    Id be guessing if the tracks arent cracked(its the most likely cause) its some sort of contact issue ...that twist and turn arrangement of the bulbs themselves can give a bad contact and can sometimes let you down...also where the cluster goes into the plugs on the dashpad...maybe the lug isnt making good contact with the circuit board or it isnt located properly in the recess in the cluster.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    writeoff's Avatar
    VS Wagon
    Jul 2011
    After an afternoon of tinkering, it appeared the simple fact of using LEDs instead of incandescent globes caused the issue. Even though it work perfectly for a week (it was a 600 km week) NFI why it decided all of a sudden why it wouldn't work...
  1. Installing A Vr Instrument Cluster Into A Level 1 Cluster Vn Exec
    By badly_drawn_boy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-07-2011, 02:41 PM
  2. Vx Dash cluster level 2 into a VT with Level 3. is this posible ?
    By Madhouse_Dave in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-12-2010, 12:33 AM
  3. Strange things after changing from VN Level 1 cluster to VP Level 2
    By vsspack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-03-2010, 09:45 AM
  4. VT Cluster Illumination pin
    By BIG-EV in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-08-2009, 05:26 PM
  5. Dropping Level 3 Cluster into unready Level 2 ready VS
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-01-2009, 03:56 PM
