Where do you guys buy the O rings that go on the heater pipes which lead to the lower intake manifold on the ecotec? Mine seem to need replacing every time I pull the thing apart. Do we just have to go into holden spare parts and bend over every time?
Just use some blue rtv. Mine hasnt leaked since. And for a tube cheaper then the o ring, can you go wrong?
VR and VS error codes:
VS V8 DTC/Error codes comprehensive list.
VS V6 DTC/Error codes comprehensive list.
I've tried the black RTV, that didnt last 5 seconds. I might just have to get the genuine ones and then order a bunch of them from a rubber manufacturer for the inevitable next time(s).
I went through this last weekend. I bought a VRS gasket kit because I needed to change my inlet manifold gaskets. The smaller heater pipe O ring in the gasket kit would not seal, it kept rolling off as I pushed the pipe in. It was thicker than the genuine one I ended up getting.
Anyway, the bloke at the Holden Spares place told me that the orange coating on the genuine O ring melts to help form a seal. He said this is probably why they are so expensive. So it may not be a good idea to just buy a bunch of O rings from just anywhere.
For it to work, and i have blue rtv on it, drain it, seal it, let it dry over night, then add water.
i just used a cheap o ring i got in a pack or 50 from cheap discount stores, and a little blue sealant, not a drop and ive done it to 3 vs/vt's and its been a couple years
Why do you keep pulling it apart?
I got them both for $15 from holden when I did my manifold gaskets.
95 VS Berlina
http://forums.justcommodores.com.au/...ml#post1891856
I need some statesman/ calais woodgrain for drivers side panel!!
I was told the genuine O rings had a flat edge?
95 VS Berlina
Can you guys please me a part number of the o/rings.
"Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
My VS II Berlina Wagon
MY12 II SV6 Sportwagon
95 VS Berlina
The other one is 24502846. Just ordered both of them. I figured for the sake of 12 bucks I dont want to risk the RTV blowing out and dumping the coolant.
