Results 1 to 17 of 17
Thread: Trans slipping after 2 weeks off the road
    VS Equipe
    Jan 2011
    Adelaide, SA
    Default Trans slipping after 2 weeks off the road
    Hi Guys.
    Got a weird one for you.
    My Auto trans has around 180,000-200,000km on it and was shifting perfectly as always (never redlined/driven excessively hard)
    I took it off the road for 2 weeks and garaged it while I did a few small jobs (exhaust mounts, paint, detail, wheels rego etc) nothing mechanical though.
    Now I got it re rego'd yesterday and went to take it for a drive last night and as soon as I get out onto my street it slips terribly from 1st to 2nd (just revved from 3-4000RPM then slid into 2nd)
    ever since it has been getting progressively worse to the point that when I floored it tonight it just revved to the redline and sat there for around 3 seconds before jumping into 2nd.
    Does anyone have any ideas on what could have caused this....the engine and trans weren't touched while the car was off the road.
    The dipstick still says the trans is dead on full and the oil is still a good colour.
    Would it be worth getting a trans specialist to check it out or should I just get a second hand box (can't really afford that after all the other stuff I have just done though)
    Could it be something I could repair myself like a solenoid?
    96' VS Equipe (Current Project/Weekender) (CLICK HERE)
    Resident VR/VS Addict
    ve ss
    Sep 2011
    sydney
    Need to know wat year model of ur ride. Sounds like a solenoid or some chips cooked if it's a late model trans equips with computer shift. Otherwise u may need a set of new clutch. They r all inside the box, so u may need to get the box overhauled. Do not buy the second hand box, they r not so cheap plus u don't know when it will die again...good luck
    VS
    Jul 2010
    Sunshine Coast, Queensland
    Check your error codes for solenoid failure. Also its worth a shot, for $12, to put some transmission treatment in. Youll find it with the injector cleaner and shit. Seems to work abit better with that stuff.
    The_Doctor is offline Banned
    VE SSV Series 2 Redline
    Sep 2011
    I would get a transmission specialist to have a look if it was me, OR have a smell of the trans fluid and see if it has a burnt smell, you could put a transmission service kit in it and generally when you put the kit in you drain the fluid, fill it with fresh fluid, run the car and then drain the fresh fluid before filling it again with fresh fluid. You would be looking about about $30 for a transmission service kit(gasket,filter,pickup) and probably another $40 for the fluids. It may not fix the problem though and maybe still need a mechanic to have a look.
    VS GTS & VT XU6
    May 2011
    dont keep driving it your burning it out and killing it quicker it sound like loss of pressure a service could help but to do it all of a sudden while its been doing nothing sounds odd small chance some craps in the valve body and blocking pressure and got to harden or the likes while sitting not sure but would get it to a trans shop asap
    VS GTS & VT XU6
    May 2011
    VS Equipe
    Jan 2011
    Adelaide, SA
    Thanks guys.
    For the ones asking what car it is its a 96 Series 1
    I will do a service on it tonight and see how it goes (will also check for anything noticably wrong).....failing that I will take it to a trans shop.
    There are no codes, so probably not a solenoid.
    Just seems so odd that the trans was perfect, then after 2 weeks off the road it would just die
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    Mine was slipping due to the trans filter slipping down into the pan.
    I would avoid reving it when it slips like that, cooks the fluid then the box....
    VS Equipe
    Jan 2011
    Adelaide, SA
    Well gave it a full service tonight.
    Went to take it for a drive and if I go full throttle off the line it will just bounce off the limiter until I release the accelerator.....only if I do that will it change into second.
    Thinking maybe a solenoid?....failing that a loose band?
    Its not showing any error codes but I suppose that doesn't completely rule out a bad solenoid
    VS
    Jul 2010
    If you still havnt got it fixed before sat, when I get home I'll type up the testing procedures for the solenoids. That requires pan off again tho. I know my tcc and 2-1 solenoid is ####ed yet no error codes logged. Check your old filter and fluid for shit, if you have chucks in it, it may be a clutch..
    VS Equipe
    Jan 2011
    Adelaide, SA
    Ok. so its not bouncing off the limiter anymore which is good.
    Its just slipping between 1st and 2nd at high revs (anywhere between 4000-5500)
    It changes ok, not great but ok at low revs but high revs it slips pretty bad.
    Sounds just like the bands need to be tightened/adjusted.....thoughts?
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Sounds like your trans could be on its way out. However, one thing you could try is replacing your TPS (Throttle Position Sensor). A faulty TPS doesn't always set a DTC and can cause delayed and harsh shifts, particularly the 1 -> 2 shift. Check out the instructions/diagram below:
    Attached Thumbnails Attached Thumbnails Trans slipping after 2 weeks off the road-tps-v6.jpg
    VS Equipe
    Jan 2011
    Adelaide, SA
    thanks, will see if i can pick one up from a wrecker tomorrow
    VS Equipe
    Jan 2011
    Adelaide, SA
    Quote Originally Posted by BlackVXGTS View Post
    Sir next time you are in Adelaide I will buy you a beer.
    You just saved me $500 (had a new trans booked in for next week)
    Borrowed a mates TP sensor overnight, fixed the issue straight away.
    Just on a side note, what is the sensor that sits ontop of the throttle body?
  15. #15
    VS
    Jul 2010
  16. #16
    VS Equipe
    Jan 2011
    Adelaide, SA
    ok so new development.
    Thought it was the TPS, replaced it and still having issues.
    Its only slipping when shifting in and out of first.....usually at around 4000+ RPM
    Someone suggested to me to unplug the TPS and take it for a spin and see if it shifts properly at 3500RPM....well it didn't it took until around 4000RPM with the TPS unplugged to shift up. so I guess that rules out the TPS/ECU
    Trans fluid is still a healthy colour.
    It shifts fine if I drive it gently and but if I floor it it slips.
    anything else I can try before buying a new trans
  17. #17
    VS Equipe
    Jan 2011
    Adelaide, SA
    Would it be worth a shot changing the torque converter considering it seems to be slipping at higher RPM.
    Would have thought if it was a dead auto it would slip all the time.
    The torque converter would make sense as the problem only occurs if I go hard on the throttle and put the car under load.
    If I drive it lightly it shifts perfectly
  1. trans slipping ???
    By W8INL9 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-08-2010, 11:21 AM
  2. trans slipping in top gears
    By gizz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2010, 05:54 PM
  3. VN V6 Trans Slipping on up and down shifts
    By goldvnaero in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-04-2009, 10:46 PM
  4. trans slipping
    By controlled chaos in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-03-2008, 04:18 PM
  5. Auto Trans Slipping? (VS)
    By nado69 in forum General
    Last Post: 26-09-2007, 12:41 PM
