Results 1 to 21 of 21
Like Tree1Likes
  • 1 Post By seq4x4
Thread: need help on ecotec..... nnnoooowwwwww
    Vs Statesman
    Oct 2011
    Harden Nsw
    Default need help on ecotec..... nnnoooowwwwww
    hi all. i need help pretty much now coz im in melbourne and need to get home in nsw..... my vs statesman has stuffed up this morning.... idling and running ok. but as soon as i take my foot off the throttle it thumps and splutters and shit from the air intake... on both gas and petrol.... ive tried cleaning the coil packs. replaced the fuel pump and filter..... and im at a loss.... i need advice on how i can fix it so i can safely drive home.... ppppllllleeeeeaaaaassssseeeeee help me asap.....
    VS Executive
    Nov 2011
    Great Ocean Road
    when you say it idles fine, but when you take your foot off the throttle it dies, do u mean on deceleration? or you use throttle to start it and it starts ok, then you remove your foot and it dies?
    does it drive at all?
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    Sounds like a dirty MAF, IAC Valve or TPS. Try giving all these a clean and also your throttle body. Have any error codes been lodged?
    If it's not a Symptom its not relevant, and if its not relevant I don't care!
    Vs Statesman
    Oct 2011
    Harden Nsw
    ok... the car does drive fine under power... but when i take my foot off to roll or apply the brake the car starts thumping from the air intake and spluttering... i tried cleaning the coil pack contacts and i replaced the internal fuel pump and filer. but it still does it. took it for a bash around frankston north and it went like the clappers.... both rears spinning and went hard.... but i did that to see if something was blocking up air/fuel intake and it seems to be ok now... still missing a bit but seems to be ok... i dont want to get half way home (from frankston, vi. to harden, nsw. about 650ks)..... especially because my son will be in the car with me..... thanks for the advice fellas. hopefully i can find the problem and fix it shortly....
    VS S Pack
    Sep 2009
    As Black Stig suggested try cleaning your MAF, IAC and have you checked for error codes - you only need a paper clip to check them here is the how to check the error codes
    Checking error codes VR/VS (Revised)
    To me it sounds like your IAC might be very dirty or stuffed and letting too much air in causing it to lean out at idle
    VS Executive
    Nov 2011
    Great Ocean Road
    are you sure there isn't a misfire or maybe one of the leads could be damaged or not connected properly?
    scvs6's Avatar
    scvs6 is offline Donating Member
    1995 Holden VS Berlina 3.8L Supercharged V6 L67
    May 2011
    Ballarat, VIC
    This is probably unhelpful but could it be possible that the air filter is blocked and needs replacing or just cleaned out?
    Quote Originally Posted by Jasper44
    For all you kids out there, when your about to have sex, just remember that it would be better if you went out and shot a police officer with a bazooka instead.
    Including car parts (VS, VT, VX, VY, WH etc), my WH Statesman, and other things listed on eBay.
    VS
    Jul 2010
    Sunshine Coast, Queensland
    Oxys, tps, iac. Does it almost die going into gear from park or neutral? If not, it's not the tps. I'd go with iac before oxys. Check error codes. Iac of eBay is about $40 or from Holden for more then that.
    Vs Statesman
    Oct 2011
    Harden Nsw
    i checked the codes and im getting code 23 mass air temp high voltage and 76 air/fuel ratio variation between left and right banks... how do i go about fixing those problems?
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    You need some MAF/contact cleaner to clean the MAF sensor. Super cheap auto sell that. Simply unscrew the maf sensor and spray the hell out of the insides with the cleaner. See if that clears up the errors. If 76 remains you have have screwed the oxy sensors which you would be best to get from a wrecker. Simple to remove and install with a shifter.
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    VS
    Jul 2010
    Your kinding about second hand oxys? Always replace with new ones. $140 for the pair of direct fit 4 wire oxy sensors from repco. Their a 24mm spanner.
    Dec 2008
    Of course new is ideal. But old mate sounded like he was in a hurry, and local stores may not have them in stock. Sensors from a wrecker are a sure find, and would get him out of trouble.
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    a/f variation will may be an earthing problem with the 02 sensors. There's a how too on this site on how to fix this i believe. Prob worth either trying some 2nd hand sensors, nothing wrong with that to test... or wire up fresh earths for the 02's and see if that works
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
  15. #15
    VS
    Jul 2010
    The problem i have with buying those sort of things from a wrecker is the fact that they dont test them half the time and you COULD end up with faulty sensors and out of pocket. Not saying thats the case with every wrecker. Its abit of a gamble.
  16. #16
    1996 VS BT1 SS 5ltr original
    Apr 2008
  17. #17
    Vs Statesman
    Oct 2011
    Harden Nsw
    Thanks all. Problem seems to be fixed... Moisture where it wasnt ment to be. Now ive got a new problem. I locked my car up and disconnected the battery over night to reset the ecu. And accidentaly closed my bonnet. No luck breaking in so cosidering smashing the rear door window. Would a standard vs commodore window fit on a vs statesman?. Cheers for all the help
  18. #18
    VS UTE, HT MONARO REBUILD
    Dec 2010
    no i dont think it will, there is many ways to open the bonnet without pulling the bonnet lever in the car, i believe that you can get a screw driver into the bottom of the bonnet popper and twist it or something and it should pop open.
  19. #19
    VS S Pack
    Sep 2009
  20. #20
    Vs Statesman
    Oct 2011
    Harden Nsw
  21. #21
    Vs Calais S1
    Nov 2011
    Colac Victoria
    to get the bonnet up lay under the radiator and there is a spring on the bonnet lock unhook it and the bonnet will pop and you can open it like you would if you pulled the cable
  1. rocker covers from non ecotec motors onto ecotec - does it work?
    By Gus The Snail in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-07-2011, 08:57 PM
  2. [NSW] 2003 Heron White VY II S Boot Lid & Spoiler + Ecotec Engine Cover + Ecotec Alternator
    By jr689 in forum Parts And Other Items For Sale
    Last Post: 20-06-2011, 11:26 AM
  3. engine swap from vs ecotec to vr s/wagon(non ecotec)
    By gumby05 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-05-2010, 06:33 PM
  4. [Ecotec] ecotec auto to ecotec manual conversion
    By jimmythefish in forum V6 Development And Modification
    Last Post: 12-11-2009, 04:44 PM
  5. Fluctuating idle on deceleration in 3.8 V6 auto (ECOTEC and non-ECOTEC)
    By cliffo78 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 25-04-2009, 12:02 AM
