Hey guys just wondering is it safe to run a shortern belt on a buick v6 motor.As a picked up a brand new driving belt today,installed it myself,but just not 100% sure if its safe or not,could u help me out...
Questions:
1)Should i take the air compressor off,that the old belt use too run
2)Does it give more hp???
3)Should i keep it on or take it off
PRO and CONS
thanks 4 the help Jordz
p.s sorry about the spelling tired as #### lol any help could go along way.I dont use A/C btw....
my other ride has tits..
it's not unsafe to do so, just make sure the shorter belt is the correct tension. technically you will get a very small improvement in power without running an A/C compressor but the difference would not be noticeable really
thanx bro,yea kind of went around the block,kind of feel abit more take off in 2-3 range.....cheers thou![]()
Do what I did and take out the whole air conditioning system it will lose about 10-13kg's from the weight of the car.
VT V6 fitted with DMS gold 40mm coilovers, Whiteline adjustable swaybars & strut brace, 330mm AP racing brakes, Rebuilt 3.45:1 LSD and a Powerdyne supercharger
Check it out: http://forums.justcommodores.com.au/...-v6-racer.html
it won't make much difference at all, it's the same as driving around with the ac off..... make sure the belt is at the correct tension and that it is within range on the tension gauge... probably not a good idea to turn the ac on without it turning as it may burn the coil out in the front of the compressor as it won't be turning getting air flow or it may not, just disconnect the plug on the green wire about 10 cm's away from the front of the compressor and tie it up out of the way so it doesn't get caught in anything.
cons:
you won't have ac on a hot summer day when it might be nice to have.
you'll save more weight if you leave the spare tyre, jack, the heavy black lining on the bonnet and all carpet in the boot at home than pulling all the ac system outDo what I did and take out the whole air conditioning system it will lose about 10-13kg's from the weight of the car.
It's illegal to vent the gas into the atmosphere, regardless of which type of gas r12 or r134a they both cause damage to the ozone layer r134a
breaks down sooner but will still cause minor damage.
Disconnect the power connector and leave the compressor there. You, or someone you want to sell the car to, might actually want it someday.
Theres not a lot of power to be gained in any case. You'd be better off putting the right belt back on and just hitting the 'off' switch on the AC if you dont want to use it.
Any power increase you can feel in a Commodore by simple removing the AC belt at the moment is all in your head. The power difference will be measurable but not noticeable. Tiny, not worth doing.
Until you turn the AC on its just freewheeling. Almost no power loss at all. Its just an extra pulley with no load on it until the AC clutch engages.
Is it safe to do what you've done? Yeah, sure, just pointless.
Thanks heaps u guys,took her 4 a 660km trip today, engine light came on for a while,got a bit scared pulled over turned car off,back to normal......But she went very good so i would say its safe to run lol
But THANKS AGAIN cheers Jordz
Makes changing engine mounts easy too. If you dont use it, remove it. Cheaper belts, one less pulley to buy and its cheaper to run without it then using the aircon.
VR and VS error codes:
VS V8 DTC/Error codes comprehensive list.
VS V6 DTC/Error codes comprehensive list.
