Results 1 to 5 of 5
Thread: can vacuum leak cause automatic transmission to downshift?
    VSII Ute
    Feb 2010
    WA
    Default can vacuum leak cause automatic transmission to downshift?
    My automatic suddenly began misbehaving. It won't shift 2 to 3 until 60 km/h even with gentle acceleration. This is on level road with no passenger or cargo added.
    RPM much higher than normal, never seems to reach 4th gear. At least I don't hear any klunks, rattles, buzzing or other worrying sounds.
    I had a major service a month ago, and they changed the ATF and filter. I checked the level, and it is okay. I get no PCM error codes. The economy-power switch is working.
    I can't see any hoses or wires come off under the hood. Also the engine temperature seems a bit higher than normal. I know some cars use intake manifold pressure as one of the factors to decide if engine is under load - does the Commodore?
    ve ss
    Sep 2011
    sydney
    VS Executive
    Nov 2011
    Great Ocean Road
    my auto i just replaced did very similar things. does the fluid seem dark in colour? does it smell? i'd say the bands in your auto are on the way out.
    jesse_lankey is offline what to put here?
    VS S3 Ute
    Jan 2010
    id be putting my money on the throttle position sensor, even more so if you have a vacuum leak and it would explain high RPM aswel
    Jaymz's Avatar
    Jaymz is offline Donating Member
    VS Exec 1996
    May 2005
    Hamilton, NZ
    Quote Originally Posted by nathanshnoz View Post
    ^This happened to my trans as well. Fluid was a horrid brown colour and smelt BAD. Had been an issue for awhile. You will also notice your fuel economy will be horrible now too.
    You won't like me when I'm angry. Because I always back up my rage with facts and documented sources. - The Credible Hulk
  1. VY V6 Automatic Transmission Leak
    By wortus in forum VY Holden Commodore (2002 - 2004)
    Last Post: 11-10-2010, 07:12 PM
  2. Automatic Transmission fluid leak
    By Domaz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-05-2009, 11:04 PM
  3. VL Auto Transmission - Rough downshift from Overdrive
    By grazm in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-08-2008, 12:31 AM
  4. help with a vacuum leak
    By iillstevellii in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-03-2008, 09:55 AM
  5. Vacuum Leak
    By maginoodle in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-04-2006, 11:27 PM
