Results 1 to 6 of 6
Thread: VS L67 Exhaust
    scvs6's Avatar
    scvs6 is offline Donating Member
    1995 Holden VS Berlina 3.8L Supercharged V6 L67
    May 2011
    Ballarat, VIC
    Default VS L67 Exhaust
    Hey guys,
    I called up the exhaust shop that we use at work and I asked them about a twin 2 1/4 inch exhaust system for my VS L67, because a few members on here suggested it.
    They said that because the car is lowered and because the car has a live axle, it is impossible to fit that exhaust setup to my car. They said a single 2 1/2 inch with twin 200 CPI cats and the pacemaker extractors will be alright.
    I already have the extractors and the 2 1/2 inch cat back exhaust fitted so that means that I just need the cats. Anyway, I was quoted between $550 and $650 because they need to make up a Y piece.
    Anyway, what do you guys think, does that sound like it should be alright or should I get another opinion from a different exhaust shop?
    Cheers,
    Ben
    Quote Originally Posted by Jasper44
    For all you kids out there, when your about to have sex, just remember that it would be better if you went out and shot a police officer with a bazooka instead.
    Including car parts (VS, VT, VX, VY, WH etc), my WH Statesman, and other things listed on eBay.
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    a few things to remember which ever way you go:
    1. there are no heat shields for the cats, so they won't be able to be tucked up to high, unless you want carpet fire...
    2. make sure you get the ends cut of the extractors (just after the oxygen sensor bung), and reflanged. they are 2.5" at that point. The standard outlet if only 2".
    3. Keep in mind what your going to do with the car. If you plan on a lot in the next short while, single 2.5" is prob going to be too small.
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    If its stock that'll be ok I guess, but with any minor mods the L67 really benefits from an unrestricted and free flowing exhaust. Tell the exhaust place their full of it as its been done many times... Im running twin 2.5" all the way to the tips on my vs.
    If you cant find anyone to run twins up over the diff then you could run a single 3" from the diff back. It will drone a little more though.
    Z' Series HSV 297KW 6lt LS2 Conversion For Sale!
    PM Me For Details
    scvs6's Avatar
    May 2011
    Ballarat, VIC
    Sorry about the late replies guys, I wrote up this post yesterday and not long after I got really sick and had to lie down, feeling better now.
    Quote Originally Posted by wamboin23 View Post
    Yeah I want them to be put just behind the transmission. I lowered the car again this weekend and if they put the cats next to the transmission, they will scrape on the ground haha. Put I want to be able to remove the transmission sump easily as I service the transmission every 20,000kms. I don't know what else i'm going to do to the engine, all I know is i'm keeping the car so anything could end up happening. I would like to get an intercooler setup and another supercharger pulley kit, not sure what else. Thanks for mentioning the ends of the extractors, ill mention that to them as well.
    Quote Originally Posted by cander24 View Post
    I believe you that you can run 2.5 inch twin all the way, you would think twin 2 1/4 inch would be easier, maybe its too much work for them. I was thinking of a 3 inch exhaust before the diff but I don't want to get it done and then i'm not happy with it because of droning. It's auto as well so it will drone.
    Another question, is 200CPI cats right?, i'm really not sure what that even means as I don't do alot of work with exhausts.
    wamboin23's Avatar
    Apr 2009
    Wamboin, NSW
    200cpi cats are what I've got (200cpi been 200 cells per inch) and are high flow enough for just about any six.
    not sure on drone at cruising speeds, but mine drones at about 80kph, which, with a standard geared diff, would prob be about 100kph. thats manual with a big resonator.
    scvs6's Avatar
    May 2011
    Ballarat, VIC
    Ok, and do you mind me asking, where about are your cats located on your exhaust system? (Next to the gearbox, behind the gearbox, etc?), but I just realised that it probably doesn't matter because mine is auto so there is less room anyway. Your cats probably fit next the the gearbox with no problems.
    My WH Statesman with the catback exhaust drones at 80km/h, the VS doesn't really drone at all with the current exhaust system.
  1. any problems changing a V6 LPG single exhaust to a V8 dual exhaust?
    By Flashback in forum VE Holden Commodore (2006 - ?)
    Last Post: 20-08-2011, 08:11 PM
  2. [VIC] FS Monasro exhaust, vx ss exhaust, K&N filter, various Maf's LS1 turtle shell & more
    By SenatorMike in forum Parts And Other Items For Sale
    Last Post: 10-04-2011, 10:39 AM
  3. Steam coming out of exhaust, also notice liquid sitting in exhaust tip
    By v8s&2wheels in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-07-2010, 12:35 AM
  4. [VIC] Swap my sports exhaust for stock standard exhaust - vu ss - cat back
    By supachippy in forum Swap / Wanted to Buy / Trade
    Last Post: 21-06-2010, 12:05 PM
