Results 1 to 7 of 7
Thread: Should radiator fan turn on at ignition?
    VS Equipe
    Jul 2011
    ACT
    Default Should radiator fan turn on at ignition?
    Just doing my cooling system and noticed a big sign on the fan shroud warning that the radiator fan will turn on with ignition.
    But mine doesn't. It does turn on with the A/C so I am just wondering if this is normal for a 96 VS (series I). It's 30 degrees outside today to boot. There's some other electrical gremlins going on, so maybe getting a little paranoid but hoping to rule this out as an issue.
    cheers
    vs commodore
    Oct 2009
    Tamworth NSW
    You can check the operation of the cooling fan on the VSV6 by removing the wiring connector from the temperature sensor at the front of the engine, theres 2 sensors, ones used for the ECU and the others for the temp gauge on the dash. The one with multiple wires is the one you want to remove, its the one the ECU uses. Once its removed, start the engine.After 12 seconds the cooling fan should start to rotate on low speed. Then after a further 6 seconds,the fan should switch to high speed. If the fan does this, its working correctly.It should also come on when the A/C is switched on.
    VS Equipe
    Jul 2011
    ACT
    Thanks Brett, just not sure about the location of the temp sensor. I can some wires coming off near the oil filter, another set below the thermostat housing, and more just below and to the left of the water pump pulley.
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    Here mate I don`t know how many times I have used this but shit it has come in handy.
    Temp. sensor is the shiny one.
    The other Temp. sender.
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    VS Equipe
    Jul 2011
    ACT
    VS Equipe
    Jul 2011
    ACT
    VS II Ute V6 1996
    Jan 2009
    Lake Macquarie NSW
    Just a little something about this test.
    I did this test for the thermo fan, and the next time I checked error codes, there was code logged about the thermo fan operation. I thought WTF? Then remembered I had done this test. Cleared the codes, and it hasn't thrown up any more codes regarding the thermo fan.
  1. radiator overheating when i turn the car off -__-
    By sully1997 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-07-2011, 12:28 PM
  2. Key Won't Turn in Ignition
    By wiseman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-02-2011, 06:08 PM
  3. cant get ignition to turn!!!!!
    By vxchick in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-05-2008, 09:33 PM
  4. Help needed!!! Can't turn the ignition key!!
    By BaldyA in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-04-2007, 07:26 PM
  5. help! vt radiator fans don't turn off
    By oneade in forum Electrical Wiring / Questions
    Last Post: 18-11-2005, 09:15 PM
