Results 1 to 9 of 9
Thread: hellppp few problems
    vs berlina
    Nov 2010
    Default hellppp few problems
    so ive bought a vs after owning a vp and cant figure out the vs's nigglie problems
    basicly i need a fresh pair of eyes and oppinions
    the most annoying problem is at low speeds and when i dont have my foot on the throttle the car seems to make a ticking noise to the rear of the car i suspect this is the muffler tapping on some thing cant figure out what tho, the rubbers seem fine but wanted to see if anyone has had this problem before i start an elemination of fixing one thing at a time..
    the next thing thats shitting me off is the ####ing annoying clank the car has when i stick the car in reverse from park or drive from reverse doest make any noise while changinf gears while accelerating
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    The annoying Clank would most likely be your TPS is stuffed or may need cleaning. When was the diff last serviced? Might be due for one.
    If it's not a Symptom its not relevant, and if its not relevant I don't care!
    vs berlina
    Nov 2010
    Vs Calais S1
    Nov 2011
    Colac Victoria
    hey mate i had a vs non irs with a rattle at idle or low speed also, is your car irs or not if not mine was rubbing on the phenhard rod mount on the left hand side rear check that out mate
    VS
    Jul 2010
    Sunshine Coast, Queensland
    vs berlina
    Nov 2010
    #### yeah the muffie is looking suspiciously close looks like my exhaust is moving just under an inch either side some thing tells me it's not suppost to dO that?
    VS
    Jul 2010
    vs berlina
    Nov 2010
    vs berlina
    Nov 2010
    found out the cat rooted its self and shat aa whole bunch of shit in the muffler
  1. Signal Problems Aand LPG Problems
    By reyyan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-03-2011, 08:33 AM
  2. VZ SS random problems starting and also lock problems.
    By alista in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-12-2010, 11:23 PM
  3. Id like to know common problems with air con in vt so i can diagnose my problems
    By dope505069 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-02-2010, 03:21 PM
  4. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
  5. VR Problems!
    By ramz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-11-2005, 10:24 AM
