Results 1 to 8 of 8
Thread: Removing vs statesman fuel tank
    Vs Statesman
    Oct 2011
    Harden Nsw
    Default Removing vs statesman fuel tank
    Hey all. Just wondering if it difficult to remove the fuel tank in a vs stato?. Fuel pump has shit itself and I wanna replace it and clean the tank out at the same time. Any tips?
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    Get tank as empty as possible.
    While you have the tank out you may aswell replace all the Breather lines as some mybe brittle and brake just to be on the safe side be a shame if you have to do them a few months down the track.
    If you can`t get all the parts from holden go to Ezed if you have them down there.
    Get ACdelco fuel pump same as holden and cheaper.
    Delphi parts OEM holden or not?
    Post 5
    ACDelco Australia
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    PM me with your email address and I'll send you some PDF files from the service manual.
    Vs Statesman
    Oct 2011
    Harden Nsw
    Vs Statesman
    Oct 2011
    Harden Nsw
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    Quote Originally Posted by Vs-Stato View Post
    How do I remove the throat? Are there other hoses to disconnect?
    In the inner guard there is a metal cover which is screwed on... Once that that is removed you should see how to remove it.....
    Vs Statesman
    Oct 2011
    Harden Nsw
    Vs Statesman
    Oct 2011
    Harden Nsw
    Tank is out. Now how do I clean it out?... Do I spay some degreaser in it and hose it out or is there some other way?. Thanks for the advice
  1. removing the VT fuel tank
    By graham7773 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-04-2011, 09:06 PM
  2. 1998 vs statesman v6, 80l Fuel Tank into VN V6 with standard tank
    By bj42turbo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-03-2011, 07:30 PM
  3. How to remove fuel pump without removing tank?
    By Weza in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-01-2011, 03:51 PM
  4. WTB: VS Statesman Fuel Tank
    By pimpplato in forum Swap / Wanted to Buy / Trade
    Last Post: 06-05-2007, 11:31 AM
  5. Removing VL Fuel Tank
    By joshtaylor87 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 14-02-2006, 09:08 AM
