Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By James39
Thread: Steering Sound
    V6 Ecotec White Vs Commodore Utility
    Sep 2010
    Western Melbourne
    Default Steering Sound
    Yet another steering sound,
    ive uploaded a sound file at http://www.2shared.com/audio/zalRd8Ja/Memo.html
    I believe it is coming from the right hand front of the car, maybe the strut tower, could also be a drive belt (i.e. power steering rack).
    ANY HELP would be greatly appreciated.
    HSV---'GO FAST HOLDEN'
    Sep 2010
    Western Melbourne
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Try another sound link - that one is full of spam and crap and if I wasn't running Linux I'd be in trouble!
    Also do some elimination - jack the front up and turn wheels with engine off to eliminate PS pump. etc.
    Sep 2010
    Western Melbourne
    VC SL/E A3300 ,Looking for a VL
    Mar 2011
    armadale Perth, Australia
    Mught sound stupid but check your fluid even just a bit low it can sound horrible mine did the same thing after i bought it
    best of luck mate.
    Black_Stig
    If Cars could scream Rape, I'm sure yours just did because I just eye fuc&ed the shit out of the above images.
    MY 1980 VC SL/E Exhaust Note
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Sound file requires you to download the .exe file and instal etc.....there are better ways to do this....someone will know.
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    Quote Originally Posted by hako View Post
    What are you clicking on? I had no such problems... I cannot tell from from that audio . you may have air in the lines or lack of fluid...........
    Sep 2010
    Western Melbourne
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Got the audio this time but like James39 it gives no clues. Maybe give a more detailed description of the problem...what revs....hot or cold....PS fluid level OK?....any PS fluid leaks?....has steering been worked on lately?....is there any feedback thru the steering wheel when noise appears?
    Sep 2010
    Western Melbourne
    Thanks for your time guys,
    The sound is obviously very metallic, sharp and short during tight turns as the car moves from a stand still.
    Can only get the sound when at almost full lock, and I move from a stand still position.
    I've checked fluid, drive belt and pulleys. I have not yet jacked it up to test power steering pump while engine is off.
    I'm beginning to think its intermittent, and maybe worth just waiting for the problem to worsen before attempting to diagnose.
    Easy to fix a hard fault ey
    Thanks once again, let's see if anyone else has had similar sounds.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    It may just be the steering hitting the end stop....this is metal to metal and sometimes makes a clunk....or from your description it may be a worn radius rod bushing that allows the wheel to move about on full lock.
  1. clanging sound after changing steering rack
    By jestah in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-04-2011, 07:09 PM
  2. swishing sound from steering
    By metalfossil in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-01-2009, 01:12 PM
  3. Water gushing sound coming from behind steering column
    By modcon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-09-2007, 11:50 AM
  4. does this sound like the comman vy power steering shudder ?
    By evil_monkey in forum VY Holden Commodore (2002 - 2004)
    Last Post: 11-09-2007, 11:02 PM
  5. VN Steering Scraping Sound
    By azkwazere in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-08-2006, 09:52 PM
