guys got vr v6 that wont start or even turn over like it has a flat battery but tried new battery and no deal tried new earth tested starter moter all good but still nothing and the negative wire to the battery gets really hot any ideas??
any ideas would be great
The negative cable will get hot due to a loose/bad/corroded connection.....it must be clean and tight otherwise it will create resistance and heat up. Also check where it meets the body/engine.
yea already checked that replaced the earth to the body completly
What about to the block?
The Daily VN T5V6
355 VN GRP A REP
also chech the connection to the starter moter, if its corroded it could cause this? also as said the main earth to the engin or just to c if its the main earth get another earth strap and put it from the negative batery and bolt it to the engin and then try
Engine Seized ?? Hydraulic locked ??? Water in cylinder ??
Can you rotate the engine by hand ??
