Results 1 to 11 of 11
Thread: VS Commodore Gurgles loudly when cold... (Video)
    VL
    Oct 2009
    Default VS Commodore Gurgles loudly when cold... (Video)
    G'day
    Well, I've sort of inherited my partner's VS Commodore with dual fuel.
    It's got a couple of minor issues such as a misfire about once every 1000km for 10 seconds, and occasional rough shifting (clunk) when taking off in a relative hurry.
    The question for this post is why does it make such a racket when it's cold?
    Gurgledoore - YouTube
    A quick Google search didn't reveal anything obvious.
    The noise goes away after a few minutes and is only audible from outside.
    Cheers, Mike
    scvs6's Avatar
    scvs6 is offline Donating Member
    1995 Holden VS Berlina 3.8L Supercharged V6 L67
    May 2011
    Ballarat, VIC
    If my car was doing that, I would replace the thermostat, then I would probably get the radiator checked to see what % it is blocked.
    Quote Originally Posted by Jasper44
    For all you kids out there, when your about to have sex, just remember that it would be better if you went out and shot a police officer with a bazooka instead.
    Including car parts (VS, VT, VX, VY, WH etc), my WH Statesman, and other things listed on eBay.
    Mar 2004
    Sounds like the serpentine belt or the pulley bearings.
    Spray some WD40 on the belt while its running, if it shuts up, its the belt
    If not, remove the serpentine belt and rotate each pulley and feel for roughness, also check for side movement by moving the top and bottom
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Best way to check if your pulleys are noisy is to get a long screw driver and and put the pointy end on the retaining bolt and your ear on the other while the engine is idling.
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    VS Berlina/ KJ Verada
    Sep 2006
    I'm curious to hear the outcome as i get a similar sound when the car is cold but only when accelerating... and i can hear it from inside
    95 VS Berlina
    http://forums.justcommodores.com.au/...ml#post1891856
    I need some statesman/ calais woodgrain for drivers side panel!!
    VL
    Oct 2009
    Default None the wiser.
    Hi again
    At this stage I'm still none the wiser.
    It sounds like it's coming from the air intake area - see this updated video, note that the mic is at the bottom of this camera. (Tablet)
    Gurgledoore 2 - YouTube
    It's been making the same noise consistently for months. Will check with the mechanic next service.
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    Sounds like it has vac leak as well. does not even sound like a gurgle lol
    You can take the belt off then start it for a moment with the belt removed if there is no noise then it could be one of your pulleys or you have hardly any water in your cooling system.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Also sounds like the LPG mixer is mixing liquid and gas when it should be gas only...are you starting on petrol or LPG?
    muttley383's Avatar
    muttley383 is offline Donating Member
    VR 383
    Sep 2007
    Throttle stop position may not be adjusted correctly, causing the IAC to have to open to much to control the idle when cold.
    muttley383
    VL
    Oct 2009
    Quote Originally Posted by hako View Post
    Is that the tick-tick sound I hear alternating from one side of the motor to the other every 1/2 second?
    The little LPG gauge near the steering wheel flashes LPG and has a solid Petrol light for the first few minutes. Once it's on LPG the LPG light stays on the and the Petrol light goes out. However, that click-click sound is present just after startup even when the indicator shows petrol as the source.
    I recently had to get this little issued - perhaps it has screwed up something down the line...
    At the time, the mechanic claimed it had twisted around and touched the exhaust or something like that - which seemed strange since it is sitting high and dry when I took this photo. Either someone saw it and tied it up in that state, or ....
    Anyway, they taped it up, car died an hour later, they cut it and rejoined it and it's been OK since. We think
  1. VZ Commodore Doesnt Start [Video]
    By Ryan2e in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-09-2011, 10:54 PM
  2. Replies: 2
    Last Post: 29-07-2011, 10:54 PM
  3. Replies: 0
    Last Post: 28-07-2011, 01:39 AM
  4. fuel tank gurgles when engine switched off
    By greenacc in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-10-2008, 10:56 AM
