Results 1 to 11 of 11
Thread: Tps problem
    Vs Statesman
    Oct 2011
    Harden Nsw
    Default Tps problem
    The tps on my v6 vs stato is playin up. Do I replace it or can I fix the original? Cheers
    vn executive series 1 v6 1989
    Sep 2011
    maryborough
    yeah i have a problem with my vn tps aswell the enging light is on and i did a ecu check and its for the tps so i changed it reset my ecu and the engine light is still on and i did another ecu check and its still coming up fot the tps so its got me beat.... whats the problem with urs
    Vs Statesman
    Oct 2011
    Harden Nsw
    Wants to die as a change from park to reverse then reverse to drive... Nothing serious, just annoying lol
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    Vs Statesman
    Oct 2011
    Harden Nsw
    Sep 2011
    maryborough
    yeah i dont have that problem but i dont know what mine is
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If you lose or forget to replace the drive adaptor when removing/replacing the TPS it will not work.
    Vz 05 sv6
    Nov 2011
    Gold coast
    If your battery voltage has been low at one point like below 10 volts it will bring up engine light, just because sensors won't be gettin required voltage therefore tells the ecu there is a fault, check wiring and the plugs in the circuit, Even give ya throttle body a spray and check vacuum lines, I've come across heaps of problems similar and some can just be the smallest bullshit things
    Sep 2011
    maryborough
    i have cleaned the throttle body and my battery is almost stuffed i get just over 2 songs with out the car turned on and its flat
    Sep 2011
    maryborough
    Quote Originally Posted by hako View Post
    what is the drive adaptor? and when i put the foot down it sort of lags/chokes then the revs go up.. would the tps be causing that?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The drive adaptor is part of the TPS and can drop off when removing/replacing the TPS....if you haven't removed the TPS it will not be a issue.
  1. [VR-VS] How To: Fix the VS V6 4 Wire O2 sensor earth problem – Known Holden Problem
    By ephect in forum Holden Commodore How-To's
    Last Post: 17-01-2012, 11:25 PM
  2. VK v8 breathing problem/oil pressure problem
    By Bookanun in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-12-2010, 03:02 PM
  3. idle problem, very difficult to find problem
    By calais s2 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-07-2010, 10:51 PM
  4. Central locking Sv6 problem. this going to be a problem car??
    By philsv6 in forum VE Holden Commodore (2006 - ?)
    Last Post: 21-04-2010, 10:40 AM
  5. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
