Results 1 to 7 of 7
Thread: thermo fan
    Dec 2007
    Default thermo fan
    hi
    is the vs v6 alternator able to keep up with au thermo fans put on.
    which is best (power draw/blowing air) out of a 16 in aftermarket one in a homemade shroud au fans or the vs one
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The alt will cope no problems....the standard VS 2 speed fan cools efficiently so I personally would not bother changing it. If I wanted extra cooling power I'd fit a larger radiator. My VS has lived in Mt Isa, Townsville and Toowoomba and temps never been over 3/4 except when the water pump seized - temp went up like a rocket in 100 metres and overheating alarm chime sounded. Replaced 2 pumps and one radiator plus all hoses in 8 years.
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    I agree, the standard fan is pretty efficient.
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    Dec 2007
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by shonky12 View Post
    what about 2 aftermarket fans set up as push and pull
    Problem with that is when the front fan is off it acts as a blockage to normal airflow....plus the aircon condenser is in the way.
    Dec 2007
    is a large aftermarket thermo fan or 2 smaller ones ok and if you put au thermo fans on will the vs alternator cope and is getting a aftermarket switch for one side to cut in at lower temperature and either using the original wire or running a new one from the aircon for the other side ok
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    You can get the ECU reflashed to turn the fans on earlier if desired. Can you also please explain why you want to alter the factory setup. The VS alternator put out 90 amps and the AU fans drag about 15 amps but it is not that simple because you will also have the aircon on (25amps) plus at night you have headlights and spotties (30amps) and a big mother amplifier (80 amps)....push the fag lighter and all the fuses blow! ----so there is no easy answer unless you can provide all the variables.....you can hotwire the fans easily to come on at a flick of a switch.
  1. Thermo in Vk help
    By Gudgeon Pin in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-01-2011, 07:57 AM
  2. thermo fan on a 5L
    By stateo 304 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-11-2010, 11:25 PM
  3. vt thermo fan
    By brett1987 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-10-2010, 01:58 PM
  4. thermo fan
    By kniever in forum Electrical Wiring / Questions
    Last Post: 10-05-2007, 10:35 PM
  5. Thermo fan always on??
    By northmelb2001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-09-2006, 01:38 PM
