Results 1 to 14 of 14
Thread: Couple of A/C issues (VS)
    VS Equipe
    Jul 2011
    ACT
    Default Couple of A/C issues (VS)
    Hi,
    Couple of things going on with the A/C or Fan..
    Air comes out pretty strong (now that I've fixed resistor block, thanks forum), but when I am going up hills it kicks up an extra notch and comes out even stronger. Car back on the flat and it goes down again. Having a flick through here I'll take a wild guess it's a vacuum problem but would appreciate some clues from someone who knows A/C.
    Other thing is it's just generally slow for the heater to come on. If I start the car cold on a hot day the cool air comes out instantly, but hot air takes a long time to kick in. Is this expected with a cold car? I guess there's no heat until the engine warms up..but I started out working on motorcycles so A/C is my weak point
    Never had this regassed in 6 years by the way.
    cheers
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    First problem will be vacuum for sure. you'll find the air won't actually be coming out faster, but will switch to window, and it sounds louder (generally).
    It's usually caused by a leaky selector switch, or a broken actuator valve.
    The heaters do take a long time to heat up, been that the engine is a big lump of cast iron, it takes awhile.
    If the temp gauge is up, and there is still no heat, good chance you've got a blocked heater core.
    If the A/C is still cold when turned on (anywhere from 4-8°C) then you really won't get much out of an A/C service.
    VS Equipe
    Jul 2011
    ACT
    Alright thanks, will go through the vacuum checks and see how we go.
    p.s. another thread mentions rough idle as a symptom of vacuum problems so I think this is definitely it.
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Hot air will also take a long time to come on if you have a faulty thermostat that is stuck open.
    VS Equipe
    Jul 2011
    ACT
    is this the engine thermostat at top of engine block?
    VS Equipe
    Jul 2011
    ACT
    By the way, yet to trace this but I noticed that there is a loud sucking noise when I turn the air routing dial to any position. Would this indicate the leak being in the console?
    cheers
    VS Equipe
    Jul 2011
    ACT
    Ok I traced everything and found the hose on the manifold was a bit loose, so snipped and reattached. That doesn't explain the noise from behind the vent selector though. Those hoses look fine. Anyone know what this noise is or if it is sign of a problem?
    cheers
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The noise from behind the selector may just be from the hose being off or split, however they do break internally and suck air and then need replacing. See the How-to on installing a radio for removal of the unit. You might be able to get a mirror up there to have a look. Good Luck.
    VS Equipe
    Jul 2011
    ACT
    Thanks for the tip. Yeh I think it may be internal, the hoses look fine and the noise is coming from the area of the switch. I've posted a video here: VS Commodore - Vent Selector Noise - YouTube
    Jaymz's Avatar
    Jaymz is online now Donating Member
    VS Exec 1996
    May 2005
    Hamilton, NZ
    Quote Originally Posted by yrebrac View Post
    Nope, that is performing exactly how my VS vent selector switch does. If you leave the switch part way between the options you can get it to release all the air and then starting the car will re-do the vacumme.
    If the fan speed feels like it is getting faster then it sound like more voltage is getting to the fans. My Mazda 6 does this when AC is on.
    When you say faster, how fast is the air coming out?
    You won't like me when I'm angry. Because I always back up my rage with facts and documented sources. - The Credible Hulk
    VS Equipe
    Jul 2011
    ACT
    If that noise is normal then good news, I may have fixed the problem by getting a better seal at the manifold.
    I'll take it for a spin this afternoon once I get that damn console back on and see what the fan and vents are doing now..
    *cross fingers*
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Mine is totally silent as I turn it - when I first pulled the dash I broke the back of the switch and repaired it in a manner that the back is tightly clamped to the front so maybe that's why it is totally quiet. With the engine off it will still switch to 3 different positions on residual vacuum.
    VS Equipe
    Jul 2011
    ACT
    Yeah, still have a vacuum leak under acceleration so makes sense it's the switch. Another post says they do fail, so I'll go ahead and rip it out.
    VS STATESMAN s3
    Dec 2011
    KEYSBOROUGH 3173
    The problem is vacuum control, u pull out the control unit and on the back u will see all the vaccum line, that bit the vaccum lines go onto replace that, part number is sp0130, should be able to get at burson or repco..
LinkBacks (?)
  1. 25-01-2012, 06:10 PM
  1. vs ute, couple issues
    By kramer in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-12-2009, 12:42 AM
  2. VP Exec, a couple of issues - LPG Guage and Horn
    By Navigator in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-06-2009, 11:55 PM
  3. Couple of issues
    By chrisco in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-06-2008, 02:48 AM
  4. vp calais. couple of questions n issues
    By mason_luke in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-08-2007, 10:25 AM
  5. A couple of issues....windscreen washer and power steering
    By MasterOfReality in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-05-2006, 01:46 PM
