Results 1 to 3 of 3
Thread: 304 problem
    vr v8 ute
    Nov 2011
    brackenridge
    Default 304 problem
    hey guys, sorry if it has been covered before, but i have a vr ute with the 304 in it. the problem is it stalls when i put it in drive or reverse. it starts first time, idles fine, even if you rev it past two or three grand an put it in gear, it simply stops. starts fine immeadiatley afterwards tho. any help would be much appreciated.
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    When you say it starts fine immediately afterwards, do you mean that then it doesn't stall when you subsequently put it into drive or reverse? Does this happen when the engine is cold as well as hot?
    vr v8 ute
    Nov 2011
    brackenridge
    it will keep stalling, if i pump the pedal a heap, it sort of stays alive but not for very long. it happens both cold an hot
  1. [VR-VS] How To: Fix the VS V6 4 Wire O2 sensor earth problem – Known Holden Problem
    By ephect in forum Holden Commodore How-To's
    Last Post: 17-01-2012, 11:25 PM
  2. VK v8 breathing problem/oil pressure problem
    By Bookanun in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-12-2010, 03:02 PM
  3. idle problem, very difficult to find problem
    By calais s2 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-07-2010, 10:51 PM
  4. Central locking Sv6 problem. this going to be a problem car??
    By philsv6 in forum VE Holden Commodore (2006 - ?)
    Last Post: 21-04-2010, 10:40 AM
  5. vent problem and horn problem
    By plasmid2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-06-2008, 10:53 PM
