Results 1 to 14 of 14
Thread: Transmission Swap (Compatibility)
    VS Equipe
    Jan 2011
    Adelaide, SA
    Default Transmission Swap (Compatibility)
    Hi Guys.
    As some of you know my transmission is shagged.
    Its a Series I VS with a 6HDD trans.
    Now I have a wrecker who has a 8HDD and claims its from a VS and will fit a VS but upon researching the 8HDD appeared to be from a VT.
    Can anyone confirm this? and I assume if it is from a VT it won't go straight into a VS.
    Also can anyone confirm which box's will work as a replacement for a 6HDD.
    Thanks
    96' VS Equipe (Current Project/Weekender) (CLICK HERE)
    Resident VR/VS Addict
    scvs6's Avatar
    scvs6 is offline Donating Member
    1995 Holden VS Berlina 3.8L Supercharged V6 L67
    May 2011
    Ballarat, VIC
    I have a VY transmission in my VS and it all bolted up fine.
    Quote Originally Posted by Jasper44
    For all you kids out there, when your about to have sex, just remember that it would be better if you went out and shot a police officer with a bazooka instead.
    Including car parts (VS, VT, VX, VY, WH etc), my WH Statesman, and other things listed on eBay.
    VS Equipe
    Jan 2011
    Adelaide, SA
    Quote Originally Posted by superchargedvs6 View Post
    Really, I heard the bell housing was different between the VS and later models
    scvs6's Avatar
    May 2011
    Ballarat, VIC
    Yeah the bell housings are different. With the VS Transmission, you can't remove the bell housing because its part of the Transmission, with later models, you can remove the bell housing because it is separate to the Transmission. You may need to use the different brackets that bolt to the side of the engine and then the bottom bell housing bolts go into it.
    VS Equipe
    Jan 2011
    Adelaide, SA
    Ah I see.
    Would ideally like something that is a straight swap as I will be picking the trans up next weekend then taking it to a mechanic to be fitted the day after and don't want to be paying extra for mucking around (just don't have the time to do it myself, and I only have jackstands which from past experience is too much effort for a trans swap)
    If anyone could confirm if the 8HDD is a straight swap that would be great, if not I will try and source another 6HDD
    scvs6's Avatar
    May 2011
    Ballarat, VIC
    Oh ok, yeah it would be better to get more opinions first. I have only done it once, but someone else might have more info on it.
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    Get the 8HDD internals swapped into your 6HDD... Then you're laughing
    If it's not a Symptom its not relevant, and if its not relevant I don't care!
    VS Equipe
    Jan 2011
    Adelaide, SA
    Quote Originally Posted by Black_Stig View Post
    Hmm, think that will end up costing me more than just sourcing another 6HDD box.
    Think I will just search for a 6HDD
    Got a reply email from the one selling the trans, the 8HDD was from a Series 3 VS
    '08 Accord Euro
    Feb 2006
    Quote Originally Posted by scvs6 View Post
    The OHDD's had a removable bellhousing - which were from a 2000 model VS. I am not sure at what exact year holden did introduce the removable bell housing during their VS models, but it was done during the VS lineup.
    The first letter i.e 6, 7, 8 etc etc relates to what year it is i.e. a 6HDD is from a 96 Model, 0HDD is a 2000 model etc etc
    The VS transmission were significantly 'beefed' up between their release in 96 and end in 2000. When you compare them side by side (6HDD to a 0HDD for example) everything on the OHDD is bigger, especially the torque converters. This is why there is such a high demand (thus high wrecker price) for VS transmissions - but namely the 6HDD's, because they were weak and everyone keeps killing them. By the time the VT came out Holden had sorted it and thats why there is basically no demand for VT transmissions.
    In relation to changing VS transmissions between various build years, there are 2 differences: the belllhousings and computers. All VS ones have 13 pins, but if you put an incorrect one in (transmission that is) the computer will go into limp mode. From my understanding its the memcal which causes this, so why buying a different 'yeared' trans get the computer from that car aswell.
    Secondly - as mentioned the bellhousings are different, so you'll just have to compare them side by side to see if it will fit.
    As far as internals go, there is nothing (from my experience) that stops an 9HDD for example being used in a 6HDD' car..
    Regards,
    Michael
    Auswide Spares
    Brendo169's Avatar
    Brendo169 is offline HSV Porn
    VS Senator
    Aug 2009
    WA
    try and find a 5hdd, 6hdd or 7hdd. that way your not going to run into any surprises and it should be a simple swap and drive deal
    VS S Pack
    Sep 2009
    from the research I have been doing into rebuilding my 6HDD auto, the main differences are as someone mentioned the bell housing and the electrical connection. If you get a new aftermarket wiring loom for the box(internal wiring) it will suit both the early and later boxes so I cannot see why you could not just use one of these but use the connections for the 13pin plug
    I maybe wrong but it looks like there are no other electrical differences between the 6HDD and say a 8HDD box
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    From memory 7hdd has uprated cooler lines and valve body (larger ports and solenoid in convertor lockup circuit) over the 6hdd. Both have the bellhousing as part of the case.
    7hdd will fit in place of a 6hdd if you swap over the line fitings on the case.
    VT trans in a VS requires major cutting on the bellhousing to clear the RH exhaust and the convertor cover cannot be used. IIRC the loom is a direct plugin.
    few commodores
    Feb 2011
    victoria
    Quote Originally Posted by Brendo169 View Post
    5hdd and 6hdd are different and can't be swapped.
    Brendo169's Avatar
    VS Senator
    Aug 2009
    WA
    Quote Originally Posted by Jxw View Post
    incorrect as some are the same. i should have been more specific in my post. A 5 hdd from a vs (13 pin) should be totally interchangeable with a 6hdd and a 7hdd. However a 5hdd from a vr (12 pin) is not the same and would not be interchangeable without loom and computer modifications
  1. transmission swap
    By graham7773 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-05-2011, 10:19 AM
  2. Transmission swap?
    By Jarmizz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-06-2010, 07:19 PM
  3. VN Transmission change and lowering.. help in compatibility
    By saint_matrix in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-05-2010, 10:19 AM
  4. V6 auto transmission swap
    By MY-42-VT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-08-2009, 01:02 AM
  5. Transmission swap
    By stuee in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-01-2008, 12:25 PM
