Results 1 to 9 of 9
Thread: Vs oil in coolant question
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    Default Vs oil in coolant question
    Hey guys. Serviced the vs the other day and while checking the fluids I noticed the coolant looked slighly oily in the overflow bottle as well as some brown sludge around the neck where the radiator cap goes.
    The car has 147,xxx k's on it and drives fine, though maybe slightly down on power compared to a couple years ago, but no missing or carrying on and the oil doesnt have water in it which sort of says its not a head gasket.
    My question is could it be the inlet manifold gasket? I know these do go on them but its not something I've had happen so just after some opinions.
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    Im Tipping the Inlet gaskets. Pretty common, you could try tightening the inlet bolts and give your radiator a flush. But you have to remember the gaskets are 15 years or so old now.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The brown sludge and oily feel around the neck could be normal if your car is being serviced by the book. Holden recommend you add 6 or so coolant "pellets" which are supposed to lubricate the water pump. The also leave a deposit identical to what you describe. So if your car has been serviced "by the book" then it may be OK. Check the owners handbook for a better explanation.
    Other than that, if the car is not using coolant, never has overheated and otherwise drives Ok, then I'd keep an eye on it but not panic. Good Luck.
    Hangman's Avatar
    Jan 2010
    Yeah drives good, doesn't overheat, burn oil or lose coolant or anything. Just happened to notice it the other day.
    Thanks for the replies fellas, I'll keep an eye on it.
    Fun_Bucket's Avatar
    Fun_Bucket is offline Gay Country Rapper
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    You can do the inlet gaskets as peace of mind, they aren't very difficult, won't set you back any more than $100
    Hangman's Avatar
    Jan 2010
    This is true. Might have to grab me some gaskets
    Vs Calais S1
    Nov 2011
    Colac Victoria
    Hangman's Avatar
    Jan 2010
    That's a thought, though there was no reddish tinge or anything. But I'll have a look anyway.
    VR Acclaim
    Sep 2008
    Kingsley WA
    I've just replaced the inlet manifold gaskets on the Acclaim (186,000 km) and my son's Lexcen (218,000 km) after signs of oil in the coolant and small amounts of oil around some bolts securing the inlet manifold. If you do careful inspection around the manifold, you may find more signs of leakage. It took me the best part of the day to do each one, but it is a fairly simple job.
  1. Ve coolant question!!
    By kizza50 in forum VE Holden Commodore (2006 - ?)
    Last Post: 19-08-2011, 09:22 PM
  2. Coolant question....
    By Maxo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-08-2010, 01:43 AM
  3. Another coolant question
    By avanti_rider in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-06-2010, 05:49 PM
  4. Coolant question
    By quombone in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-05-2009, 02:09 AM
  5. coolant question
    By fishman in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-01-2007, 11:56 AM
