Results 1 to 24 of 24
Thread: How accurate?
    Vs Statesman
    Oct 2011
    Harden Nsw
    Default How accurate?
    Hey all.... Just wanting to know how accurate are the distance to empty meters? And if they arent exact is there a way to calibrate it so it is?.
    Thanks for any advice...
    Vr ss & vy v6 wagon
    Jan 2010
    Central Coast, NSW
    not very accurate, they are more for giving you a rough idea of how far you could go before running out of fuel.
    Vs Statesman
    Oct 2011
    Harden Nsw
    Ok cool. Thanks mate.... Mine said 110 till empty but then the gauge rwad empty and I ran out haha. Had to get a tow 30ks into town.. F*#king thing lol
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Calibration is the same as for the VN Calais
    VN L3 Calibration - How To!
    and 3 Dangerous non ABS VN's
    Vs Statesman
    Oct 2011
    Harden Nsw
    I have the handbook for my car. Didnt even think of lookin in there cheers mate
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    I find mine and mates cars are pretty spot on down to the last 10-20km. Altho we have all calibrated ours.
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    Vs Statesman
    Oct 2011
    Harden Nsw
    Yeah. Mine said I had like 110 to go bur it was completely empty... Looked at tgat link but it looks to complecated to calibrate haha
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by Vs-Stato View Post
    If you run full tank of fuel every week - just take note of the pump Lts and the tank Lts used - post up here and we can tell you what the numbers need to be.
    The default numbers are 625 for distance and fuel flow (often reset by nasty car sellers to show good fuel ecconomy) With ign on press and hold the set button for 3 secs in each of the 3 modes and record the numbers.
    VS Berlina/ KJ Verada
    Sep 2006
    I believe it's a good way to gauge fuel usage and deter heavy acceleration, as the DTE fluctuates as you drive, basically telling you, for example, if you've filled up and keep flooring it off the mark or to get up to speed you will get say 250k's to empty, if you correct that style of driving, half an hour or so later it will have changed to something more reasonable like 400 - 450 till empty. Does that make sense? Thats what mine does anyway!
    95 VS Berlina
    http://forums.justcommodores.com.au/...ml#post1891856
    I need some statesman/ calais woodgrain for drivers side panel!!
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by SWE11L View Post
    The trip computer updates every 2 mins - so the longer you drive without resetting the more stable it gets. If you reset every tank full then it will jump around a little (bit like the 1 day cricket score graphs - smooth out to a more or less flat line that = the run rate).
    When the car gets to less the 50kms to empty it starts to update every 30 seconds.
    Vs Statesman
    Oct 2011
    Harden Nsw
    Hmm ok... At the moment it says 570 till empty with half a tank on the gauge... Dont think thats right haha
    Sep 2006
    Quote Originally Posted by 88GreenVN View Post
    Thanks for that info mate.
    I think yours is rooted!
    95 VS Berlina
    Vs Statesman
    Oct 2011
    Harden Nsw
    Hahahaha it sure is mate.... I want to get it as close to accurate as possible. But it seems to complicated....
    Vs Statesman
    Oct 2011
    Harden Nsw
    Current numbers on my dash are trip time 2.34....fuel used 12.78l...... Dist trav 136.1km..... Avg speed 53.0..... Fuel avg 9.3 l/100km..... Thats since last reset.... Tank gauge is completly full withit just over the f.... And dist to empty is currently reading 940.... I know that aint right haha... Any way of making it more exact (simply for us dumb folk) please?...
  15. #15
    88GreenVN's Avatar
    Jun 2006
    Press and hold the set button for 3 secs with the Ign on. While holding the the set button tap the up or down button to adjust to 625 for factory default setting. Do this for the distance and fuel flow.
    The other mode is the fuel remaining in the tank. So the 60 and 80 switch on the bottom of the cluster sets the base numbers to work from and you adjust it up or down the same way. Needs to be done on level ground too.
    See how it goes once the factory defaul setting are done.
  16. #16
    Vs Statesman
    Oct 2011
    Harden Nsw
  17. #17
    Vs Statesman
    Oct 2011
    Harden Nsw
  18. #18
    88GreenVN's Avatar
    Jun 2006
    the other setting thing is 70l and 0cal?
    Could be that the cluster is set to the wrong size tank. Is yours set to 60 or 80?
    The 70L and 0cal looks to me that you have 70 lts fuel in the tank and it's calibration has not been changed.
  19. #19
    Vs Statesman
    Oct 2011
    Harden Nsw
  20. #20
    Vs Statesman
    Oct 2011
    Harden Nsw
  21. #21
    mischa's Avatar
    Jun 2005
    Ashbury, NSW
    There is a switch on the back of the cluster.
    The Daily VN T5V6
    355 VN GRP A REP
  22. #22
    Vs Statesman
    Oct 2011
    Harden Nsw
  23. #23
    88GreenVN's Avatar
    Jun 2006
    If it's an 80 Lt tank then it should be OK - unless the cluster has been changed at some point.
    I found with my wagon (68 lt tank) that if I had it set to 80 it would give silly high readings with the DTE. I dont think that will be it for you tho if it's the original cluster in the car.
  24. #24
    Vs Statesman
    Oct 2011
    Harden Nsw
    I wouldnt know mate... Im the 4th owner... I will take out the cluster and check it gor a couple of popped globes anyway... Knob 2 bords with one connie haha
    Thanks guys... Will let ya know
  1. VT - Fuel indicator screen not accurate?
    By Orpheus in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-08-2011, 06:24 PM
  2. Speedo on VP not working / not accurate
    By VPchick in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-11-2010, 06:04 PM
  3. L3 Trip computer not accurate
    By dans_vz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-07-2009, 11:29 PM
  4. Is the elbow accurate for guages etc...
    By defa in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-11-2006, 10:14 PM
  5. 100% accurate VE Pics guaranteed
    By Pretender in forum Jokes/Humour
    Last Post: 12-04-2006, 12:31 AM
