Results 1 to 8 of 8
Thread: VS Temp Gauge with High Flow Thermostat
    VS Series 1
    Nov 2011
    Hurstville
    Default VS Temp Gauge with High Flow Thermostat
    Hi Guys,
    I lost my password for my old logins (yyg-988, and ORIXvywags)
    Ive been reading up a fair bit, on VS series I temp Gauge, and know the temp is normal
    but I changed the sender unit today, and put a high flow thermostat in the car
    but letting the car sit running, it makes the gauge, sit pretty bloody high
    just wanna know, by lookin at the pick I attached let me know what you think
    Attached Thumbnails Attached Thumbnails VS Temp Gauge with High Flow Thermostat-img_0730.jpg   VS Temp Gauge with High Flow Thermostat-img_0731.jpg
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    Replaced the Temp sender or the Sensor for the guage in the cluster?
    Maybe the thmostat is not opening or the system needs bleeding or even you could of installed the themostat wrong (upside down)
    Today I replaced my temp sender to find it was a waste of time as the fan still kicks in at the same point as the old one did lol....
    VS Series 1
    Nov 2011
    Hurstville
    Hmmmmm, the crazy thing is, I got one of the Holden Mechanics at work to do it, ..... and they said the temp it normal
    I will defo check it out tomorrow
    I just wanted the thermostat to open up earlier, improve the cooling over summer and improve fuel consumption
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Never knew they made high flow thermostats but I guess you'd only notice the difference at higher revs and not at idle. If the cooling fan turned on at 3/4 (as in the pic) then all is normal. Why did you replace the sender if you knew it was OK, and as James39 asks, was it the sender with one or two wires?
    VB SL/E
    Dec 2008
    Not quite sure I understand what a high flow thermostat is supposed to do, the way i see it, the thermostat controls temp, opening more to cool more so if it was high flow it would cool even more requiring it to close more to maintain temp??? sort of defeats the purpose.
    FYI with the high temp as stated either the system needs bleeding bad or the new thermostat is faulty or the new sender is faulty.
    Do you have a thermometer to take a proper temp reading?
    VR v6
    Jan 2011
    perth
    Mate, I'd check to see if it's really getting that hot by the looks of that temp gauge your engine would be cooking itself, but if all seems normal then more likely the sensor you installed is incorrect...
    Btw, all that a high-flow thermostat does is cool the motor more efficiently once the temp is over its set limit. By allowing more water to go through and circulate into the radiator...pretty simple really
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    If you can get a lazer temp gun, use it to check your actual engine temperature to rule out a dodgey sender.
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    You All ARE Wrong About A Commodore Being A 4 Stroke Engine... Or Any Car For A Matter Of Fact...
    A V6 CAN'T Run On ONLY 1 Cylinder... IT'S A 24 STROKE ENGINE... 4 CYCLES Per Cylinder... "Basically Three V-Twins Together
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    The temperature sender unit used in VS V6s was carried over from VRs, but the location was changed to a hotter part of the engine. This may cause higher temperature readings on the gauge before the thermo fan cuts in. In mid 1997, the sender unit was revised to suit the new engine position and engine temperatures, and shows a lower reading on the gauge before thermo fan activation. You may have replaced the sender unit with a pre-1997 unit, particularly if you purchased an after-market version.
  1. vn calais fuel gauge/temp gauge cluster voltage board
    By JuZo!!! in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-07-2011, 01:19 AM
  2. oil temp/water temp gauge wiring
    By HUMBLZ in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-05-2011, 04:53 PM
  3. Temp gauge reading to high.
    By 1998GTS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-06-2010, 06:26 AM
  4. Temp gauge reading to high.
    Last Post: 17-03-2010, 03:20 PM
  5. normal running temp for a VT 5L? and temp gauge..
    By mike49 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2009, 12:57 AM
