Results 1 to 5 of 5
Thread: VS Aircon Hissing
    VS Series 2 Wagon
    Jul 2011
    Australia
    Cool VS Aircon Hissing
    Hey guys havin a bit of an annoying issue with the VS
    after the aircon has been on, when i turn the engine off there is a hissing sound for a few seconds. This also occurs occasionally when slowing down while driving.
    I have looked around already on the forum but cant find the exact solution.. Do u rekon it needs a regas (after 15y without one) or is there like a loose hose?
    It still blows cold air, but its not VERY cold...
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    Is it like a vacuum leak sound?
    Quote Originally Posted by Rufys View Post
    yup! I think I might actually be gay
    VS Series 2 Wagon
    Jul 2011
    Australia
    It is like pshhhhhhhhhhhhhhhh like air escaping. Happens every time i turn the engine off with the a/c button still pressed. i want to try to work out prob before i take it to a mechanic coz 1/2 of them are crooks and try to rip u off
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I'ts probably just refrigerant expanding in the evaporator (!) after the engine is switched off - this is normal although not always audible...just sometimes. You can duplicate this with a refrigerator - when the frig compressor is running, switch the frig off at the wall then put your ear to the outside of the frig and you will hear the gurgling sound as residual refrigerant expands in the evaporator.
    VS Executive S2 V8
    Mar 2011
    Mildura, Vic
    I once had a similar problem...
    Ended up it was the vacum connections at the back of the vent selection dial (selects fresh, recycle, demist etc). Pop out the gear selector surround, unscrew the stereo/heater control surrond, unscrew the heater selection dial unit. A little bit of vasoline around the connection and made sure it was on securely, and end of hissing.
  1. Air con hissing
    By njf690 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-01-2010, 08:43 AM
  2. Hissing from air con
    By chrisdoesitbetter in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-11-2009, 04:53 PM
  3. wiring a neon to the aircon switch to show that the aircon is on
    By 12000 in forum Electrical Wiring / Questions
    Last Post: 25-03-2007, 08:44 AM
  4. Air Con Hot and Hissing me off
    By Bradles in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-01-2006, 12:50 PM
  5. hissing VL
    By livenletspool in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-06-2004, 11:10 PM
Tags for this Thread
