hey guys. im thinkin bout upgradin from my single spinner to lsd. found a mate with a diff. he says its lsd. there are no tags that i can see though..
anyway. it is out of the other car already.
if i spin one hub should the otherside spin too or only if im doing it from the centre?
cheers
The WaJin: 1991 s2 VN Commodore WagonThe Shtato: 1994 VR Statesman
whether you spin it from the hub or the centre, both wheels should turn in the same direction.
coz i spin it by centre... both spin...
then by hub and only one does and nothin on other side...
The clutches in the LSD will wear out especially if it has had any hard work and then it is just like a conventional diff. This can happen in a very short time.
I could be wring here... but my understanding is....
Hold One output (Say the left wheel output) and spin the input... either one of 2 things will happen...
1. the opposite output will spin as long as you keep spinning the input... (NON-LSD)
2. same as above but only a for little bit... (hence the term "limited slip") it will get hard to turn without letting the output you are holding spin as well... (LSD)
Unless as stated above by Hako... the LSD is fluffed! ... then it will work like a NON-LSD...
Also, since it is out of the car, you might as well see how much backlash it has???
if the lsd/clutches/cones are roooooted. how much do u think it would be to repair.
as it is a fair cheap diff for 50 bucks.
and backlash????
95 VS Berlina
http://forums.justcommodores.com.au/...ml#post1891856
I need some statesman/ calais woodgrain for drivers side panel!!
No... Read what I'm saying... NOTE when I say input and output!
In reference to your statement... If you spin an OUTPUT on one side, (assuming the input is held) the other output will spin then opposite way in a NON-LSD. As for an LSD... I am unsure how spinning an output on one side would affect the output on the other side, as I'm not sure how the clutches will react??
