Hey all.... My v6 stato has developed a problem in the last few days.... sometimes when I start the car it makes a load pop noise and takes a bit longer to kick over. Also when im not accelerating it sounds like a motorbike idling but as soon as a touch the accelerater it stops... The car is duel fuel.. It has no affect on performance (or lack of haha). Its just annoying. Plus im swapping it on tuesday for a vt and dont want it doing that when I swap it off.... Any advice???
Have you checked error codes???
I did and I got 23 45 65.... But I have no idea how to fix them haha
Code 23 - Mass air flow sensor, Its the sensor just after the Air filter box. This will either be dirty and needs cleaning or will need replacing
Code 45 - RH O2 (Oxygen) Sensor Rich - Needs Replacing
Code 65 - LH O2 (Oxygen) Sensor Rich - Needs Replacing
The O2 Sensors are just screwed into the exhaust just after the headers![]()
If it's not a Symptom its not relevant, and if its not relevant I don't care!
Normally you fix them by replacing the parts that those error codes mention. If you are not going to do that that then you will not fix it.
My car also has the same problems at times (done it today) the only difference is that I have no error codes nor is it duel fuel.
Also when it played up the stater motor made a weird sound like the bearings or winding are shot.
Ok cool.. Thats easy enough.. The plug isnt in anything as previous owner added a pod filter and the sensor itself is out of tge box lid,and snapped.... Tho oxygen sensors are easy as I have replaced them before on my old vs
My VS used to come up with those 3 codes all the time, and after trying to fix them for a while, I later on found out that those codes only came up because the car was on LPG, (and I have noticed all commodores on LPG that come into work have those 3 codes). Now that my VS is only running on unleaded petrol, theres no codes.
Originally Posted by Jasper44
Including car parts (VS, VT, VX, VY, WH etc), my WH Statesman, and other things listed on eBay.
^ As above, you need to have your MAF plugged in as your ECU needs to be having information sent to it so it can arrange the correct fuel to air ratio. It could also explain your O2 Sensors are sending back information about it running Rich.
Hmm.... Could be that lol.... That other plug is on. Just the one that goes on the lid is off... Ill get another lid and try it out..
