Hey, i decided to remove my dash to paint it, now im a bit stuck.
Firstly is the actual vinyl bit supposed to come off with a plastic backing or do you just peel it off?
There seems to be some rivets, how have other people got to them and cut them off?
Are you supposed to take off the long strip at the back?
Thanks
Will
Yeah the long strip near the screen but cant you paint it in the car just mask up.
Originally Posted by 87RB30VL
Huh? I got given the gun of my neighbour,
Na wanna do it properly.....I got the right side clip off but it seems to be stuck in there, im afraid of snapping it?
there is 2 screws as well i pulled mine of to get my tweeters under there, have a look from the other side of the window you will find them
After doing the whole pull the dash out to respray and then put it all back all I can say is next time I decide to do it I'm doing it in the damn car and the screws in the vents near the windscreen are a bastard!
what sort of paint did you use to paint the dash?
Just used the VHT vinyl dye in satin black. Came up verrrry nice![]()
I ve just scored a drivers side glove box that came out of a VQ statesman and need to paint it grey to suit the grey statesman interior I've got in my ute - do ya reckon I could use the same sort of stuff? It's currently blue?
T_C
Yeah mate if VHT has it in its vinyl dye range
hey 97VSV6 just saw that you are located in Vic - where did you source the VHT? Can you get from a local car joint? ie. Autobarn etc ??
cancel last post - just went to their website (should have done that prior to posting) Apologies![]()
