Results 1 to 4 of 4
Thread: 1993 vr v6 t5 gearbox problem
    vr wagon
    Nov 2011
    brisbane
    Default 1993 vr v6 t5 gearbox problem
    i just picked up a vr wagon cheap a week ago now today when i change into 3rd gear and 4th it grinds the gears like i have not put the clutch in.
    VZ S Ute
    Jun 2010
    Castle Hill, Sydney, NSW
    most likely the synchros on 3rd and 4th. try double clutching, itll help a bit. but its not recommended to double clutch on a gearbox with synchros because youll just wear out your clutch quicker. its a problem which is only going to get worse and worse and eventually your going to have to pull off your gearbox and get to work
    vr wagon
    Nov 2011
    brisbane
    ok, so i should look for another box. would the box do this if the wrong oil was put in aswel
    VZ S Ute
    Jun 2010
    yea i'd be keeping my eye out for a new box. pulling apart a box just to change a synchro is a messy and time consuming job. but make sure the box you buy hasnt got the same problem.
    if you put the wrong oil in then your going to cause some premature wear. just look at a gregorys and see what oil is meant to go in
  1. vy gearbox problem can anyone help
    By vy supercharged in forum TTT Performance Engineering
    Last Post: 14-09-2010, 05:35 PM
  2. VR Gearbox Problem
    By Ben_VP_Calais in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-08-2010, 10:55 AM
  3. 1993 vr commodore fuel problem
    By peowpeow in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-02-2010, 08:01 AM
  4. gearbox problem
    By big balls in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-02-2009, 08:09 PM
  5. 1993 Hsv Clubsport Starting Problem
    By hldngrlnz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-10-2007, 02:04 AM
