Hi Guys,
Picked up a spare boot lock from local wreckers,
the white plastic circle thing on the barrel of the lock.. as you turn the key it hooks the arm that pulled the boot latch and opens the boot.
Anyway that broke on my original boot lock, hence picking up the spare
Anyone know if its possible/how to take apart the barrel of the lock to remove the white plastic circle to transfer it to my original boot lock
(or direct me to an existing thread)
Thanks guys!
Had a look at mine but cannot see any 'easy' way but there must be. Check along the side of the barrel as sometimes there is a spring loaded pin you push in to release the lock part of the barrel which you can then swap.
Good Luck.
