Results 1 to 6 of 6
Thread: 5th Gear pops out when not under load
    VS Commodore 5Litre 5Speed
    Nov 2011
    Cairns
    Default 5th Gear pops out when not under load
    Hi all, my second day as a member and my second question.......
    Any ideas why my t5 box would pop out of 5th when not under load.ie when coasting down a hill.
    Is this a fluid issue, shifter or more serious ?????
    Any ideas guys?
    Thanks..
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Worn 5th/rev selector sleeve or hub.
    Bent 5th/rev shift fork.
    Excessive endfloat in 5th gear.
    Weak/broken shift key springs.
    You could try an oil change but I doubt anything will improve.
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    or easier still... just check if the rubber covers under the plastic plate are pulling too hard in the lever
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    bpefi is offline Tech
    Hilux Ute - Vs Ecotech Engine
    Nov 2009
    Bundaberg
    VS Senator
    Nov 2009
    VS Wagon 3.8 Manual
    Mar 2011
    Dandenong
    the rubber gear boot was pulling mine out of second gear, so i would take the boot off and see if that fixes it since it is a fair bit easier than pulling the box out and overhauling it
  1. VX Making load tinging noise under load
    By Commodoreluc in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-09-2011, 06:34 PM
  2. My nan and pops VH VACATIONER !
    By CalaisGirl in forum VB - VC - VH - VK
    Last Post: 20-06-2011, 11:38 AM
  3. 2nd gear pops out
    By wagon_vs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-03-2011, 04:32 PM
  4. vp has a miss & pops under load
    By girl racer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-12-2007, 12:43 PM
  5. wen hot stalls. Wen under load misses and pops
    Last Post: 11-12-2007, 10:30 AM
