Page 1 of 2 12 LastLast
Results 1 to 25 of 38
Thread: Mods and recommendations for fuel efficiency
    VS Acclaim Series 2
    Oct 2011
    Perth - Cockburn
    Default Mods and recommendations for fuel efficiency
    I know this is probably asked a lot, but wondering on any stories on how much fuel efficiency I can expect to gain (If driving nicely :P) with a CAI, and possibly pacemakers and a high flow exhaust?
    Also, what's a good store to go to in WA?
    zapper-l67's Avatar
    zapper-l67 is offline LS# Eat One Today...
    VX Calais
    Jan 2010
    Western Vic
    Is it a 6 or 8 ?
    This is the sort of stuff that happens when the kids get into Dads tool box over weekend.
    Money will be spent, Dreams will be shattered, Lessons will be learned, and a wealth of information will be gained.
    VS Acclaim Series 2
    Oct 2011
    Perth - Cockburn
    3.8L V6, VS so an Ecotech if that makes any difference. It does have gas, but for some reason it just keeps stalling when I try on gas.
    The_Doctor is offline Banned
    VE SSV Series 2 Redline
    Sep 2011
    A simple answer, NONE. I put a CAI on my SSV Redline and it sounds so mean when I plant the foot now my fuel economy is about 20l/ 100km, before it was 14
    VS Acclaim Series 2
    Oct 2011
    Perth - Cockburn
    Hahah I know I'll probably get carried away with it, but if I drive nicely I'd assume it's better for my fuel lolz, of course if I floor it it'd get more air etc. and use more fuel I'm aware of that though
    VS Acclaim
    Jul 2011
    NSW
    The amount of fuel saving that can be made by certain mods will never return the savings to ever pay for the mods, as the savings in fuel will be so small.
    Also if you are concerned about fuel, aftermarket extractors and a cat back will reduce fuel efficiency as a result of loss of torque down low (2.25" cat back will minimises this)
    I'm not saying don't mod your car, just that I wouldn't be going out to mod my car because I want my car to be more fuel efficient.
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    I believe you can buy a memcal that leans out the lean cruise even more, run the correct tyre pressures and don't carry excess weight in your car. extractors and exhausts don't really save fuel and a cold air intake puts more air into the engine (colder air is more dense) so the computer has to fix the mixture by adding more fuel anyway.
    ========My Statesman 20's Mafless and 3.9's========
    VS Executive S2 V8
    Mar 2011
    Mildura, Vic
    What sort of ecomony are you currently getting for what sort of driving? An ecotec should be good for about 8-9L/100Kms country driving on 91RON.
    The most obviously solution is to get your gas issue sorted out, so regardless of the economy, it will be cheaper to run.
    As far as cheaper add ons, you could try a K&N type air filter to let it breathe a bit easier, a lower temp thermostat to keep the engine running cooler (and more efficient), and I have heard good things about the plenum spacers from MACE but never tried one myself.
    In my experience a good exhaust system will also improve economy a bit and won't noticably sacrifice torque so long as it is kept to a sensible size, but with an improved note it is also likely the car will get driven harder as well.
    MR_JORDZ's Avatar
    MR_JORDZ is offline Situation
    94 csi lexcen VR v6,
    Apr 2010
    $outhside logan,Queensland
    Quote Originally Posted by ucwepn View Post
    Agree on this^
    my other ride has tits..
    Not_An_Abba_Fan's Avatar
    Not_An_Abba_Fan is online now Exhaust Guru
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Extractors and exhaust actually do improve fuel economy when cruising. If you do a lot of short stop start trips, then no they don't. Freeway driving, expect about a 10% saving on fuel as there is less restriction in the exhaust.
    Extractors on their own with the stock exhaust will give a better improvement than doing the exhaust as well. It comes down to money spent versus money saved. Most of the time, just keeping the car serviced and the tyre pressures actually higher than recommended will save more fuel. I have always run a minimum of 40psi is stock sized tyres and the fuel saving has always been noticeable.
    Getting a tuned memcal will also improve economy.
    But as I said, you can spend a lot to achieve a little so if economy is your goal, maybe a different choice of car would have been better.
    Visit my Facebook page
    VS Acclaim Series 2
    Oct 2011
    Perth - Cockburn
    No problems thanks guys, it was rooted from an argument with a friend hah, but yeah, I'm looking to mod in general anyways, though obviously say a higher diff ratio isn't going to be as good for my fuel, etc
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    If you want a good deal on the exhaust side of things and want to come for a drive to Bunbury, I can do your extractors and system at a really good price.
    VS Acclaim
    Jan 2010
    I've had terrible fuel economy since i got the car 2 years ago, I re-earthed the oxygen sensors and have seen an improvement in fuel consumption. Its a known issue with the vs as it was the 1st to use a 4 wire 02 sensor (as opposed to a 2 wire) with a heater built in. Might be worth a look. Fairly simple and cost ya next to nothing.
    I replaced the headlights in my car with strobe lights, so it looks like I'm the only one moving
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    Quote Originally Posted by wildeagle44 View Post
    It is funny that mine is the four wire and is all original and has no problems apart from one time there was a conection problem at the plug for one of the sensors...
  15. #15
    vr series 2 v6
    Oct 2009
    nsw
    Quote Originally Posted by The_Doctor View Post
    haha my fuel economy is 14 litres of premium to the 100 kms lol, with my mrs driving on open road sitting on 100 km/h, 1900 rpm or something
    mods are as is \/ \/ \/
    Vs eco 3.8, extractors, 2.75" exhaust, roller rockers, cammed, bored out 20, t5 manual, rolling on king springs all way round with monroe gt shocks all way round, every door has a ding but looks can be very deceaving
  16. #16
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by James39 View Post
    My VS is also one of the first VS's that use the 4 wire 02 sensors, and Ive never had a problem with fuel economy or bad 02 sensor readings, and have not done the sensor wire fix, the only time Ive had problems with 02 sensor readings etc when I tried to run a tune that Id done on a later release of the VS memcal. This totally stuffed up my 02 sensor readings and fuel economy, and the short and long fuel trims were way out. I tried the earth fix on the 02 sensor wires and there was no difference. I ended up doing the tune using my old memcal version as the base for the tune, and I had no more problems with 02 sensor readings or fuel economy or fuel trims. The later VS's dont seem to suffer from this problem and can use pretty much any of the VS memcal versions. Most people who sell tunes will use the latest memcal version as the base for the tune. Ive also talked to other people who have early 4 wire VS's and have ran into the same problems when trying to run the later memcal versions.
  17. #17
    VS Acclaim
    Jul 2011
    NSW
    Hmmmmmmm
    My 95 VS has two wire O2 sensors.
    So very early VS's had two wire O2 sensors?
    And I recently ordered a tune from MACE, hopefully it is tuned for the early two wire VS commodores so I don't run into issues like you speak of Brett
  18. #18
    ephect's Avatar
    ephect is online now Donating Member
    VS Acclaim V6
    Jul 2006
    yea the first vs's had 2 wire then they moved to 4 wire.. i only found this out after i did the how to earthing the o2 sensors thread.
    as previous posts, keep tyre pressures up, carry minimal stuff in the car, and service and maintain the car. wheel bearings may also be close to being shot, draging brake shoes/pads.
  19. #19
    bpefi is offline Tech
    Hilux Ute - Vs Ecotech Engine
    Nov 2009
    Bundaberg
    I have a vs / trans in a Hilux ute - I gave up on getting fuel economy from the std oxygen sensors on petrol - did all the earth fixes etc - I run it on LPG & tune it with a Lambda meter - for some reason the oxygen sensors read lean when its still rich - result poor fuel economy.
    I don't know what it is but it seems to be on later combinations of Memcal to computer - I run a dual map memcal - one tune map for petrol - one for LPG - which works so much better than trying to run it with a Petrol only map.
    I also run an Airod variable mixer - the difference between a std ring mixer & one of these is awesome - it just drives like its on petrol. They are not available new anymore you might have to look through the wreckers - though you will probably have to go with a Blos CV variable mixer - There are many posts on these on here somewhere & available at times on Ebay.
    I use Pulstar spark plugs which also makes a noticeable difference to power & fuel economy with much less backfire problems.
    I talked to Mobil & dropped to a thinner engine oil on my 2.0 L Hilux to a 0W40 full synthetic from a 20W50 Mineral oil & picked up a lot of power & huge increase in fuel economy on that vehicle - I also fitted the Pulstar plugs to that & from then on I got over 1000k per tank (128L useable) from roughly 660 K per tank.
    I have not changed the VS over as yet as I just did the motor up & set it up specifically for LPG with high comp pistons / double row timing chain etc & I have not run it in as yet. But looking forward to what will happen there.
    Running like it is I doubt that anyone would see the difference between petrol & LPG on the road & empty I think it would kill a std VS on LPG & thats before I did the engine up ... its better than ever now without the balance shaft & the high comp pistons - I run a 3.7 ratio rear end & it just flies yet I get 13 L per 100 the highway & 15 L per hundred around town - so I cant complain about that at all.
    Run good tyres & keep them pumped up well - make sure the wheel alignment is right (this can cause huge losses in fuel economy) make sure that your brakes are not dragging. Take any wind restrictions off the car (roof racks etc) & if you want to go anal - polish your car LOL - You could probably spend some money & get twin high flow cats possibly for top end anyway - I still have the std manifolds & exhaust - I dont know what difference that would make but .... for me but its custom extractors - so thats a bit scary. I have tried to make the most difference for the least amount of money & I have won on both counts so far & very happy - when I first drove it home after the mechanics fitted the LPG I just couldn't believe it - it was like a pig & now a couple of minor things & its transformed.
  20. #20
    VS Acclaim Series 2
    Oct 2011
    Perth - Cockburn
    Quote Originally Posted by Not_An_Abba_Fan View Post
    I'm quite rough on money at the moment only got about $900 but need Christmas stuff, but how much were you looking for? I go on holiday soon too, so I won't have money anytime soon but yeah it helps I'm just trying to budget and stuff now. Gonna go to an LPG specialist too.
  21. #21
    James39's Avatar
    Jul 2009
    Newcastle NSW
    Quote Originally Posted by peckzz View Post
    I get around 9 to 10 litres per 100 k's on the freeway sitting on 110...
    Just installed a big mouth air intake and soon to add pacemaker extractors... Hopefully my fuel usage will not increase
  22. #22
    Drawnnite's Avatar
    Drawnnite is online now Obviously Unsensible
    2000 Vs Ute
    Sep 2010
    it might help if you say the L/100 you get so we know if your getting it good average or bad =P
    anyway in my v6 man vs ute i can get about 8L per 100 on the freeway at 80/100/110 (speed varies)
    and about 9-11L per 100 for traffic/town driving.
    only has the S/C CAI and 12mm Mace Plenum and 12mm Mace Manifold spacers.
    however intersting fact. Dimple your car like a golfball and it will better the fuel economy =P
    how about we make the pedals out of sticky rubber and the shoes with steel spikes. at least my shins would like that
    Quote Originally Posted by Jonesy484 View Post
    yeah i wondered the same thing when i was 4 when i grabbed the chrome exhaust of my dads rx7
    Quote Originally Posted by DM 55 WA View Post
    did you think it was a milo tin?
  23. #23
    VS Acclaim Series 2
    Oct 2011
    Perth - Cockburn
    Golfball also goes faster ahah gotta love Mythbusters. I'll need to fully fill up my tank and remember to take a reading sometime.
  24. #24
    VS Executive S2
    Aug 2010
    melb
  25. #25
    hako is online now Donating Member
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The best aid to economy is a driver who operates his vehicle efficiently. There are many driving techniques which achieve an increase in fuel economy yet can make driving more enjoyable not just for you but your passengers. They can cost nothing to adopt. Back a few years the fuel companies used to run Economy Trials - they involved completely standard vehicles which had to drive from (say) Sydney to Melbourne in 10 hours. The fuel efficiencies they achieved were quite amazing and they were achieved purely through driving technique. This can cost nothing.
  1. Replies: 13
    Last Post: 06-09-2011, 10:08 PM
  2. lpg fuel efficiency on VN
    By joeyd in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-06-2010, 08:30 PM
  3. fuel efficiency mods?
    By VSaklaym in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-06-2009, 02:25 PM
  4. VE Fuel Efficiency
    By Scotty_Doesn't_Know in forum VE Holden Commodore (2006 - ?)
    Last Post: 12-01-2007, 04:24 AM
  5. Fuel Efficiency
    By Haze in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-03-2006, 08:43 PM
