Results 1 to 4 of 4
Thread: VR Problem
    Jul 2005
    Default VR Problem
    i have a 95 model Vr commodore over the last 12 months this problem has gotten worse when i start the car it will start fine and idle fine for a minute than it will idle really rough i can turn the car off than back on again and it will idle fine i can than go driving around but if i stop at idle speed for to long like in maccers drive thru on a busy day the car will start idling really rough again if i turn the car off than back on again it idles fine now this problem is at the point where its happening pretty much every time i drive the car what could this be? i have also just noticed in the last few days while driving on a highway doing 100 it sometimes has a surge but the engine kicks back in and keeps going
    cheers
    Not_An_Abba_Fan's Avatar
    Not_An_Abba_Fan is online now Exhaust Guru
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I would check the fuel filter first, but it does sound like the pump is on it's way out.
    Can you do an error code check?
    Visit my Facebook page
    Jul 2005
    thanks for the help i just checked the error code and im getting 12 which is every things normal i have a new filter i havent installed should i order a fuel pump as well or just try the filter first?
    VB SL/E
    Dec 2008
    Filters are cheap and need regular replacement.
  1. vs statesman problem, possible emobiliser problem?
    By Mbro in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-05-2012, 10:28 PM
  2. [VR-VS] How To: Fix the VS V6 4 Wire O2 sensor earth problem – Known Holden Problem
    By ephect in forum Holden Commodore How-To's
    Last Post: 17-01-2012, 11:25 PM
  3. idle problem, very difficult to find problem
    By calais s2 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-07-2010, 10:51 PM
  4. vent problem and horn problem
    By plasmid2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-06-2008, 10:53 PM
  5. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
